you only get ~20km/h more by taking it to redline in 4th. there will still be a massive burnout without it.
i forgot about the chassis dyno factor- wouldn't be able to tune through the whole rev range in 4th if you don't have the speed-cut disabled
https://www.sau.com.au/forums/topic/237735-speed-limit/#findComment-4158985
most JDM cars have a 180km/h speed cut built in
this includes R32,R33,R34
its usually a voltage signal to the standard ECU, the voltage increases as your speed goes up and reaches a certain voltage at 180km/h
most speed cut devices simply cap the signal so it never goes above say 0 or a very low speed so the ECU never see's voltage around 180km/h
there are a few ways to avoid this "cap" these are all coevered by searching, the speed cut has been done to death but as you haven't bothered to search;
1). cut the speed signal wire to the ECU (breaks HICAS diagnostics if you ever try it)
2). get a speed cut device (hks speed cut defencer, Apexi RSM, greedy make one too)
3). remap the ecu and edit the speed cut value
4). get a stand alone ecu
https://www.sau.com.au/forums/topic/237735-speed-limit/#findComment-4159191
do r33's have a limiter, i have a standard ecu and have taken it to 202k's and backed off.
Probably just means your speedo is out, which is highly likely
Do a search and you will find instructions on the wire cut as mentioned.
the moral of this thread is " use the search function ".
i concur
https://www.sau.com.au/forums/topic/237735-speed-limit/#findComment-4159223
Guest
