Fuel Pump Control Modual - R32 Gtr
Turbz_13
 Share
its behind the panel between the b and c pillar, driver side. and it is very unreliable after all this time. the easiest way to bypass it if it is your problem is to run an earth directly from the fuel pump negative to the chasis.
is this the metal box thing thats similiar looking to the attessa ecu etc in size?
we are no looking at completely removing the module all to gether. has anyone dont this before? will it be stuck on high voltage all the time once the module is removed?
removed the module and ran a separate power supply to fuel pumps via a direct feed (relay controlled).
  • 9 years later...
Bringing this one back from the dead...
My car would run for about 30 seconds - a minute then cut off. I'd let it sit for about 10 minutes then it would fire up and run again for 30 seconds - a minute again. Eventually it just wouldn't start at all.
Pulled the line off at the fuel filter and cranked the engine and confirmed it wasn't getting any fuel.
Just replaced the pump and the engine still isn't getting any fuel. Would this mod fix that?
Stock ecu, walbro 255, has been running perfect before this.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
