Just wondering lol if anyone has had there Turbocharged car in my case a (r33 gtst) signed into the company/business they work for or the company/business a parent may own in order to get an RTA exemption to drive it. For what im heard this will work as the RTA will give exemptions to drive PPlate prohibited cars if it is a company car.
Anyone tried this? did it work yes or no?
https://www.sau.com.au/forums/topic/237767-turbo-company-cars/
RTA will make the relevent inquiries, see you owned it previously, sniff out your scam and reject the application.
If they dont notice that then they will only issue the excemption for woking hours if it is a work related need that you are making the application for.
Lol yeh ur probly right, Nissan Skylines wont pass off as company car easily lol unless the RTA are dum shits which i know they arnt.
Im just gonna try and stick with the plan that because my dad is 'passin it down' I cant sell it for sentimental value reasons and if that doesnt work ill get my Parents to hold onto it until im off P's ><
    • My son saw this Porsche 904 in Yodoyabashi in Osaka, not sure if it's the plastic or fibreglass version 767605763.559358.mp4
    • I agree re not trusting it as it makes mistakes however can do hours of research for you at times by simply asking a question
    • The I've done a lot of research and feel like I'm becoming a nut and washer expert. The washer in question doesn’t look very conical—it’s almost flat, but one side has a chamfer. The guide's picture shows the convex side (chamfered side) facing the nut, but the text says the chamfer should face the pulley, which is confusing. If I follow the picture, the chamfer faces the nut, but the instructions say the opposite. When I place the washer on a flat surface, one side looks flatter—maybe that's the concave side—so I would expect the chamfer to be on that side. But it isn’t, which adds to the confusion. The term chamfer is also throwing me off. I always thought the concave side should face the pulley, and the convex side (with the chamfer) should face the nut or bolt head. But Nissan’s instructions say the chamfer should face the pulley, which seems backward. I know I’m probably overthinking it, but I want to be sure I’m doing it right. Also, I’ve seen some people replace the nut and stud with a bolt, but I assume that’s not a good idea, since it might not keep proper tension on the tensioner. Lastly, just to be 100% sure: the pressure washer should face the pulley, then the conical washer? That feels strange, since usually the pressure washer goes first, facing the bolt or nut.
    • I checked, i dont think it was the indicator stalk. The problem just magically fixed itself though.
    • H1 is not the Humvee, but is the most road based version. Lachlan (HankScorpio) on here has a proper Humvee. He imported it a few years back.
