Item: 18" wheels and tyres and spare pair of tyres
Age: about 12 months old
Condition: average - some gutter rash but still look great and cheap to get repaired
Price: im new to the whole sale thing so make me an offer
To Fit: most 5X114.3 not sure of the offset but it was on my 32gtst
Contact: 0431557314
Comments: i just need them gone as im really out of space i also have other parts for both r32 skyline and honda eg civic hatchback
https://www.sau.com.au/forums/topic/237781-18-inch-rims-and-tyres/
you must be very new to the whole skyline thing cuz you need to put up prices! its forum rules :)
lol yeah i am i only got my 32 on the road about a month ago before that i was an avid honda man
but as for the price lets go with $650ono :banana:
what kinda stuff are you willing to trade them for. i got a greddy fmic piping stock 32 rims GFB bov and two pairs of skid rims one set 18 the others 17
hey mate sorry i should have given some details im after performance enhancing parts or 17" rims
i have no need for the piping as i already have a complete kit installed, i also have a set of 16" enkies so no need for the stock rims, i also have a blitz bov so no need for that either
thanx anyway
  • 1 month later...
thanx anyway
still for sale make me an offer i dont use them anymore and need the room or if you have parts for a 32 gtst let me know im willing to trade
  • 4 weeks later...
hi all sorry about not replying to any of the pms and stuff but i had no pc for a while umm the rims are still here and for $350 they are yours i am moving soon and need all excess stuff gone
  • 1 month later...
  • 2 months later...
wheels are back up for sale as im not using them anymore sticking with the 16's
take them away for $300ono
or still willing to swap wheels and tyres for r32 parts
Edited by aahh32
other than r32 parts i am also interested in a ps2 for trade as i just found all my old drift games and wouldnt mind booting them up again
no need for ps2 in trade anymore as i got bored today and bought 1 :stupid:
but still after any drift games you might have
What is the size of the tyres? brand, condition?
the tyres are all falken ziex even the two spairs and there all 235/40/r18 but all pretty shagged.
the two spairs are pretty much brand new but with camber wear, i was gonna use them for drift.
Could you please put up a couple more photos?
these are the only other photos i can find at the moment and there really dirty but remeber its only the rear wheels that are for sale the enkei rp01's arnt for sale but there are 4 of the rear wheels i only have 2 on cos i had just gotten a flat tyre and was in the middle of swapping the wheels over.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
