Today I had a Bosch 040 supplied + fitted for $340.
Previously with the std pump 7psi (190rwkw) drove absolutely perfectly but 12psi (203rwkw whilst leaning out) was coughing and spluttering.
Now 12psi is as good as 7psi after the new 040 pump has been fitted.
Very happy because the 040 will leave me with plenty of headroom for future mods.
Originally posted by benm
Theirs no way i'll be turning it up to 15psi, 12psi is enough for me right now (I need to burn that in as it is).
Having a standard ECU means lot of things can go wrong. :D
Such as? The stock ecu throws more fuel in and less advanced timing, if anything its going to protect the engine. Granted it has a boost/fuel cut which spoils fun, but it certainly isnt going to harm the engine in any way.
would the standard pump running into a surge tank with larger fuel pump be enough? or would you need 2 pumps of same flow rate for this to work best??
anyone put a surge tank in the boot of a skyline, or are the fuel tanks baffled enough not to worry about starvation on the track??
craved, I don't know about the inner design of the tank, but I've never had a fuel starvation problem on the track (but then neither do I take it out with under 1/4 tank)
yeah neither have i, well not that i've noticed anyway, just looking for an easier way than replcing the one intank, plus the looks etc of an anodised surge tank in the boot :P
do you know if it would work or would the high pressure pump empty it too quick to be feasable?
Craved I got my Bosch 040 (520hp) intank fuel pump supplied + fitted for $340.
To get an external pump/surge tank etc supplied + fitted by UAS was going to cost basically $1,000.
Unless you drive around with your boot open I reckon the ~$600 could be spent elsewhere, like some slotted front rotors.
damn, a grand!!!
they sell the surge tanks for about $250, plus the fuel pump, the rest can be done yourself!!!
but overall just looking at whether its going to work the way i was thinking, main reason is that i have to do this setup in a sprinter as well, since the engine conversion it has major surge issues running from the VL turbo pump!! The old AE86 dont have fuel tank baffles, causing major issue at the track when less than half a tank!!
Hi guys, by plumbing it into a surge tank you take the load (resistance) off the standard GTST pump. As an example we have a GTR that uses a GTST pump in the tank pumping into a 1.5 litre surge tank with 2 X GTR pumps feeding the engine. The surge tank is never empty, the single GTST pump easily keeps up with the requirements of the 2 X GTR pumps supplying the 6 X 1,000 cc injectors.
Hope that helps
that was exactly the answer i was looking for sydneykid!!!
thanks heaps for that!!!
just one more little question: do you just Y piece the return line and the surgetank overflow before the fuel tank, or do you need a separate lines to the tank from the surgetank and return line ??
Cheers
Hi Craved, I do it a little differently than some I have seen. I return the unused fuel from the engine into the fuel tank, not into the surge tank. I have found it comes back from the engine warmer than when it went there. The compression effect of the fuel pumps, the heat transferred from the fuel pumps and the heat in the engine bay all get together to make it hotter. So if you keep going around and back into the surge tank you end up with really hot fuel which is not a good thing.
So I use a Y piece at the fuel tank for the surge tank over flow and return from the fuel rail.
Hope that helps
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
