hi all im collecting parts atm to upgrade my rb20det in my r32 gtst have got pfc, r33 turbo, 040 intank,
boost controller an jus wanted to know will i need a fuel pressure regulater for these mods
Also already got the basic mods done and later on down the track i will be installing gtr injectors afm and gettin turbs hi flowed and coilpacks ect so if i don't need the fpr for the first lot of mods will i need it later on for when i put the gtr injectors in an all that
hope that makes sense cheers
https://www.sau.com.au/forums/topic/237816-rb20-upgrade-question/
im getting confused there have been a few topics i've read and people are upgrading fpr's to adjustable ones
or is it cos i got a power fc i can adjust it on that an not worrie bout upgrading cos i will need more fuel once i start to
up the boost so can someone who definatley knows bout this explain please
With the set up you described above there is no need to replace your stock FPR nor is there a need to bump the pressure up at all with the GTR injectors.
The stock reg will be fine as its rising rate so save your money for something else :P
As the grandmaster said.
The PFC doesn't know about fuel pressure, so you can't control it from there. The factory FPR is a rising rate regulator, and as you up the boost, so you will up the fuel pressure. You get more fuel by programming the PFC to open the injectors for a longer time.
