Hi, i gave up on games a long time a ago but just wanted to let everyone know that Sporn on PC has a virus that beds itself onto you computer, i dont know much about it but it seems to watch your comuter and give back info to EA even if you try and remove the program form the computer itself
BEWARE!!!
https://www.sau.com.au/forums/topic/237850-sporn-on-pc/
Its an online check thing, that makes sure that each copy of the game can only be installed 3 times max (not sure if it counts reinstall as one), after you have used up 3 attempts you have to phone EA to get a new key.
I would assume that the "virus" you are talking about is this program that monitors this.
Ironically, if you get the hacked version, that program is removed by the hackers.
BTW nearly all of EA's latest games have this online check bit, that limits each key to a certain # of install.
https://www.sau.com.au/forums/topic/237850-sporn-on-pc/#findComment-4160159
Probably cracked already, Reloaded have already released the game as an image + the crack on torrent sites.
I found most of the new (& up coming games) from EA all have this sort of protection. like the new crysis expansion & red alert 3.
Great job EA following Microsoft's gay DRM method = I'm never buying a game with such protection, locking your key for a limit # of installs is just beyond gay. :P
https://www.sau.com.au/forums/topic/237850-sporn-on-pc/#findComment-4173223
    • A couple of months of gentle driving will be fine. There is a risk that you will kill it. A heavy workout will probably kill 3rd gear. Continued use will wreck the input shaft bearing.
    • That's because R34 RB25DET is a pull clutch gearbox. I have that clutch, behind 25Neo, in front of R33 gearbox. I have brand new R34 turbo gearbox, in a box (cardboard) in the shed right now, and it will be getting used with the same engine and clutch, because I also have, in a much smaller box next to it, the front plate to convert the new box to push clutch.
    • Are you planning to ever come on boost with the RB25DET? The torque of the motor alone will break the little box. It's not a matter of if, it's when.
    • So it should work in my case?  I does not say R34 but it say push(i have push gearbox/clutch right now) No i wont...and i do not drift/race or do anything crazy with car so even a small box should be ok for a couple of months
    • Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
