Hi all,
I changed my radiator hoses and coolant today. I was shocked. Seems the part where I attach the hose has rusted through. Any fix for this? (I've included some pics.)
Urgently need some help.
RB25DE - Non turbo
Cheers
https://www.sau.com.au/forums/topic/237858-r34-cooling-system-problems/
Wow, that's not good.
Would say you engine hasn't been running any inhibitor in the coolant system. This stops corrosion of the metal and alloy parts throughout the system. Make sure you put some in once you've fix this up.
I would say the the steel tube will need to be cut out of the aluminium intake maifold and a new pipe pressed into place.
I would recomend an engineering workshop or competent mechanic.
oh god
i was hoping to do a coolant flush this weekend
i hope i dont see what ive just seen.
hehe - i was thrown back at the sight.. pretty nasty.
Nissan was quoting $800 for the bottom half of the intake manifold, as it is 1 piece (ordered from Japan - brand new item) they do not supply the tube end.
I probably can go to a machine shop and get a new pipe inserted, but its gonna be a pain taking out the intake manifold, i wonder if they can fix the issue with it still in place,,,,
Could possibly do it in place, but you risk getting metal shavings into the system.
The intake is really too hard to take off. Take the top section off first, then it'll be easier to get at the bolts that hold the lower section to the head.
After much thought and discussion with some mates I've decided to get the exact dimensions of the rusted piece and get a custom piece made up.
I'll then chisel out the rusted piece and press fit the new custom piece.
I wonder if stainless steel would be a good idea or not - I mean would it cause a bad reaction with the coolant etc?
I've found an engineering place nearby http://www.yann.com.au/
Any thoughts or pre-cautions?
yeah man thats f*cked
your welsh plugs would be pretty thin now i recon
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
    • Seriously though, it's the Shaft Autoservice high mount rear spoiler: https://az-style.shop/items/5ffaad5a72eb464137a6edb1
