Hello all,
Re-build in progress...RB26.
Tomie restrictor(1.5mm) on the way...thanks Sean :(
Not looking for a sump extension but more of a modification.
This has been a discussed topic but not much information on hear for my liking.
It reducess pressure thus creating less blow-by
and helps maintain a good level of oil in the sump which at high revs can be low causing problems
Has anyone drilled the head and sump to improve the flow of oil?
If so, what size oil return lines did you use?
Where is the best location and height to tap into the head?
Where would it be best to return the line into the sump?
Pictures would be great if anyone has them.
Also am unsure if this mod is good for any other RB Motor.....sure it would not hurt.
Thanks
https://www.sau.com.au/forums/topic/237871-head-to-sump-oil-flow/
People have gone external oil drain (plenty of threads/pics about it now)
IMO, as long as the restrictor is fitted, for a street car you wont ever have a problem.
You only would really need a external drain if you ran a super volume pump (JUN etc) but even then, plenty of people that dont have external drains and running without issue where restrictors are properly used etc etc...
You don't actually 'drill the sump' in those words, the sump is where the oil ends up.
If you mean boring out the sump... thats a waste of money.
Ok,
So if you have a Jun,Tomei high flow oil pump fitted then this is a must.
You would then consider an extended sump.
I would think though this would be an great alternative for cars with a lot of blow-by
and hitting the rev limiter often with out the restrictor in place or extended sump.
Especially if they don't want to remove the head to fit a restrictor.
Tapping a 10mm hole into the sump and threading it would be an easy job to do.Or am I mistaken?
It may not even need to be 10mm...this is why I ask...it could be 5mm....or even 4,3.
Ok,
no... it could be considered. I wouldnt say a must at all being there are PLENTY of cars without external drains with high volume pumps (they would have restrictors and so on)
There aren't many that use it.
You can drill the stock oil returns from 8mm to 9.5mm (3/8 inch) with a long drill bit. Also drill out the 5 holes in the sump that go from the back of the sump section to the main area from about 1mm to about 4mm. Lastly you can fit an external return to the back of the head. Another idea which i will soon be investigating is a breather in the crankcase, to remove the blowby that prevents the oiol travelling down the drains.
o i see. yes, you drill out the tiny little 2mm holes in the sump, (where the driveshaft tube runs over) to 8mm or as big as you can go.
also a oil return is a must, even standard pumps will still fill the rockers up. ideally a -12 (16mm) or bigger is best for the oil return from the head. just making it as compact as you can is the hard bit given the clearance at the rear of the head.
dave here. (to4gtr)
Drilling the stock oil return makes a lot of sense, 9.5mm would be an added improvement but
what is the most they can be drilled out. Dave though has suggested these can be drilled out to 12mm.
How far can you go?
The drilling out the 1mm holes is suggested by Tomei when fitting their
oil baffle plate they though suggest 6mm. Dave has gone one better and has suggested 8mm.
How far can you go?
I believe maybe with the stock returns drilled out to 12mm, Sump return oil gallery 1mm drilled out to 8mm
combined with a Tomei 1.5mm oil restrictor may just work when the engine is out.
It would be great to have though a quick fix solution to this problem with an extra return line, maybe
picking up oil 3/4 of the way up the head 10 to 12mm line returning back into maybe 1/2 way up the sump.
Experimenting with the idea that we could vent this also to our existing catch can may lower bottom end pressure
which always ends up blowing your dip stick out on a dyno run.... :) .That is if you haven't tide it up.
Anyway, I hope this helps others
What does your engine builder have to say about it all?
Have they even built RB's before?
Yes my engine builder has built many RB26 motors.
This thread is to help myself and others make decisions on
approaching RB Oil control issues.
I now have a better understanding and knowledge after posting this thread.
It will add to the great data base on here. :cool:
In my application I have decided to keep my N1 oil pump.
Fit a Tomei restrictor,1.5mm.
Drill out the sump holes(5) from 1 to 6mm and
increase the oil line return size to 10mm.
No sump extension..not needed..add 1 litre more oil if going on track/drag.
I will not be hitting the rev. limiter much (Set it to around 8K using all forged bottom end)as it is a road car which hardly gets track or drag use.
It will add to the great data base on here. :(
We already have such a thread, and its been around for quite some time (As linked in the FI Guide)
http://www.skylinesaustralia.com/forums/Oi...ui-t110680.html
So if thats all this thread kinda serves... Then we dont need two threads on the same thing
Cheers
Guest
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
