Some of you may remember my post about getting screwed over by "mechanics" in adelaide. Since therapy i can now openly speak about that. So i thought i might get my rear quater panel fixed, obviously by a panel beater and bring some pride back into my 32.
I bought the panel myself and had it freighted to the workshop. I was told it would be ready in 4 - 6 weeks. So 2 months later it hasn't even been started yet. Just sitting in his shed looking all depressed while i drive a sierra around that can't even go the speed limit. The reason it hasn't been started is, quote; "i'm waiting on a panel beater to come over from Tasmania".
Now he is a panel beater / spray painter. I can understand if he hasn't got time because he is busy but telling me bulls**t lies has made me quite agrivated. He won't even give me a quote. So i want to take it elsewhere but after the trouble i've already been through does anybody know a reliable, reputable, quality panel beater?
I dream of a magical place in a far away land where mechanics and customers live as one and we co-exist in peace and harmony. Can anyone help???
https://www.sau.com.au/forums/topic/237878-screwed-over-again/
after seeing sambo33's car the other day i'd jave to reccomend to take ya car to him at findon crash or where my car is currently at premier paint n panel on regency road...however they charge a preimium price but do awsome work my car is finally coming together just need that front bar lol btw insurance is paying for my work so that why i took it to premiers lol
Yeah i was. I should of introduced myself properly but i wasn't quite with it that day, never a good time before i go back to work.
ah thats cool, i thought afterwards i should have asked what username you had on sau. you have a black 32 right?
oi sam, paint my car for me :)
haha. i would luke, but i got no facilities anymore, damn i miss having a shed :(
cheers vinnie, yeah where i work probably isnt the cheapest either. but we do quality work, its not like these volume shops that crank out as many jobs as possible, we take some time to get it right. :(
Edited by Sambo33
haha. i would luke, but i got no facilities anymore, damn i miss having a shed :)
your old shed made a good backyard spray booth, haha.
i miss my old shed too :( like, really really miss it.
going from the shed, with pit, and room to fit about 4 cars in, to the one i have now, which only *just* fits the onevia in, sucks!
Edited by ted180
Yeah, black 32. I'll get it back eventually... I noticed the 33 when you first got it in the bridge and then found out a little bit more through the people i'm renting a room off at the moment.
I did have a thread about rav 4's a while ago. Short is it pulled out infornt of me and took out my drivers side from front panel, door and to the fuel cap. However it was under dubious circumstances and have learnt my lesson. But i still hate them as they are a joke and can't be classified as a 4wd.
actually i think ive met you before that, i had a chat to you when u worked at dominos?
Yeah that's true, good old Domino's that was a long time ago. I used to try to talk to anyone in an import especially skylines and there weren't any other 33's that looked as nice as yours. I think Joel and Amanda had 33's but that was it. I still hear updates with your's through the roommates.
haha, that brings back memories. i remember dominos carpark always had the lineup of black 32s, normally yours, that gts-4 with the vented bonnet and sometimes that n/a one. i always parked there to go to the bank and have a sus of the other lines :cool:
cheers man, i always tried to keep the 33 clean i spose. were joel and amandas 33s the burgandy and oranges ones? do i know your roommates?
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
