  • 3 weeks later...
  • 1 month later...
bump
For those serious buyers i mite also throw in the existing pioneer 7300 fully motorised in dash screen as well as the pionner 7050 multizone dvd player as well as the 12 disk stacker that is alreadie in the car
price is basically negotiable..... if u want it cheaper basically means more stuff will be removed to reduce the price....but basically a clean decent car if u r looking for a 33 which will make ppl turn heads at the lights i get tat often..
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
