When shifting at high revs (above 5500) into 4th my gearbox goes into gear ok but gives out a crunching noise reguardless of how quick/slow i try to shift does it in 5th a little aswell. if im driving around normally the box is smooth as. Has anyone else had this problem or know what it is? My gearbox also has a faint whinning noise when in neutral that goes away when i push the clutch in. thanks:(
https://www.sau.com.au/forums/topic/23795-4th-and-5th-crunch/
Try some Nulon in your box as well.
The crunch is from worn synchros usually (sometimes excess wear can be caused by reckless shifting and leaning on the gearstick while driving...especailly 4th and 5th gear {you use these gears to cruise in offen.}).
The whining noise is more then likely the input thrust bearing, and is common in R33 Skylines.
I honestly found that "readline" made it worse. Never had the problem b4. On the last service i decided to put all the "top shelf" fluids in my car, to give maximum protection, and now at high speed/revs 5th crunches. Never did it with the previous oil, seriously thinking of draining the fluid out and going back to what worked for my car. Not sure of the brand name though :), but my mechanic knows.
Guest RedLineGTR
it varies from people to people...some people have used it and found no decent results..some have had geat results...when i put the stuff in my mates car it took and decent drive for everything to make a difference about 50-100Km so depends on driving and condition of the gearbox
thanks guys ill give the redline stuff a try, also i took the car for a spin tonight and it didnt seem that bad at first but the more i thrashed the car around the worse the crunch (the problem is only when shifting into 4th up or down, ocasionally 5th) became. In the end even in low revs it still gave a little crunch. i eventually out of despiration decided to double clutch it into 4th and whala the problem was solved changes were smooth again. Does this still mean the problem is with the sincro's or is it a clutch problem??
otto, if double clutching (correctly) fixes the problem then it is synchros. the double clutching means the synchros dont have to work coz the next gear should already be at the correct revs.
Nothing wrong with double clutching all the time tho.
I have this problem (worn synchros) in my box and redline has fixed it fine except when I am really hurrying 4->5th.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
