hello to all out there? some of you all ready know that im a mechanic and have been for a number of years dealing with performence imports of all sorts .
as ive manage to find myself a good cheap all wheel dyno and ive started setting it up in my shed hear at home and few other ins and ends i well be opening up soon hope in about 3 weeks.
ill be dealing from tune most ecu and engine building of all sorts to everyday oil changes and many other things from 4wds to GT-R"s and many other cars and also doing turbo rebuilding if need be? as ill be just starting out at home it well be very limited? but in time if all works out i well open to better doors in time and i well be importing sec hand parts from japan..As im based in hobart well berriedale buy the river front
if there is any thing els i can help u with please drop me a pm
well thank you all and kind regards mich
https://www.sau.com.au/forums/topic/238010-new-work-shop-comeing-soon/
Any experience with Nistune?
yes i can mildly retune factory ecu. but i havent delt with it much.
i can do mines ecu, apexi power fc, nismo, motec, autronic, wolf, michrotec, and many more. from mild to wild depending on your setup. and what u wish to get frome your car and in performance and what u wish to do with your car as a everyday driver to a weekend thing but as to tune most ecu's yes i can do...
i have had a few good talks with Mich and am really impressed with his knowledge and friendliness - best of luck to you buddy :P
oh and here in Tasmania, we spell the word "comeing" without that 'e' in the middle :)
lol...hehe...lets hope he tunes better than he spells.
good luck with it Mich.
I am sure there will be a lot of business for you if you can tune remapped nissan ECU's well!
Best of luck mate, might pop you a PM to give our 99' magna a tidy up (service, clutch etc) coz I can't be effed! :nyaanyaa:
I shot you a PM.
I got a car for you to tune that might give us all a benchmark of your abilities.
320RWKW with out NOS and 400RWKW+ with NOS is my estimate for my R33 so it will be a good benchmark to see how he goes with high power RBs.
Might have to go a bigger turbo so I don't need the NOS to get 400RWKW :)
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
