Sooo... I've been mucking around with my iPhone and been writing a couple of apps (one of them should hopefully show up in the iPhone store if its approved).
But I've been thinking... it'd be great to have a iPhone Consult port application. Basically I'm hoping to get a group of you guys who might have some background in programming, and interfacing with the Nissan consult system. There's two ways we can go... either legit and sell the application thru Apple, or go renegade and distro it for hacked iPhones. I'm personally in favour of the latter, but then again, there's always that lure of money and fame :cool:
Before we get carried away, a list of goals for the app:
Interface with the CONSULT port... easiest way would be to use a serial channel:
http://devdot.wikispaces.com/Iphone+Serial+Port+Tutorial
This kinda means that the application has to run on a jailbroken iphone though
Although I did come across this... a iSkin TX/RX (http://www.iskin.com/ceruleantx/) which is an official product that allows you to send audio over bluetooth... I'm not sure if its adaptable to serial communication, but with a name like TX/RX its quite interesting.
Has to show pretty gauges (something a bit nicer than Datascan does). Has to show data in realtime. This data can be in graph plots or in gauge form.
Has to be able to give the user a more human language translation of error codes, and switches available.
Has to be able to log the inputs received along with time and location. This would be a killer function for both tuning and datalogging on track days etc.
Has to make full use of the iPhone's accelerometer and pseudo-GPS. One for mapping G-forces etc, and the other for logging geolocation.
If you guys look at the app "Rev" that just got launched a little while back, they kind of do something similar with the OBDII port using a bluetooth signal. However they don't make use of the accelerometer, and they don't do data logging.
Anyways... I'm just putting this post up, so that if anyone who reads this forum is keen on the idea and can actually contribute, then they can make themselves heard. I'll be doing some more planning in the days to come, and probably try and put together a specification of some sort to work through. If you guys have any ideas, please post them up.
https://www.sau.com.au/forums/topic/238030-iphone-consult-software/
well the first hurdle is the physical stuff. i wouldnt toy with bluetooth if the iphone has an actual serial port (which is great if it does, as the tendancy these days is to just have mini-usb and thats all which blows)
if the iphone is 3v serial input then the consult cable for it would be even simpler than a normal consult cable as you just make it use iphones 3.3v as power supply, and you lose the rs232 level converter and 5v vreg
maybe drop the 10k down to 6.8k due to change in voltage from 5v to 3.3v (keep current the same).
once you can verify the serial comms (e.g send 0xff 0xff 0xff and get back 0x10) then at least we know its do-able. no having an iphone myself means i cant help much in that regard
haha mate I was just reading over some of your posts to put together a consult cable the other day. The serial input is actually a hack, using the proprietary iphone port, and some base level interaction with the darwin based unix platform running on the iphone to get a TX and RX signal. Not too sure on the voltages, I'm waiting for my iphone port breakout circuit from sparkfun to arrive so I can toy with it some more.
n95 is symbian not windows. if it was windows it could use ecutalk. but then again it doesnt even have physical serial port, only mini-usb i think? so its fairly useless trying to do anything for it unfortunately
True that, the bluetooth connectivity on the iPhone is shocking, ive done extensive training on the iPhone itself working at a Telco and working in a support role, so i need to know the iPhone inside and out ( not literally inside, if i ripped one apart i'd die :D )
The Physical port would be the way to go, or if they have some sort of " bluetooth connectivity enhancer " which plugs into the serial port and boosts connectivity to keep it constant and accurate, with less data loss.
The Tilt feature would be awesome, but im guess you have to build the base version first just like any new program / software. Then add on bits and peices as the beta versions progress, to a final public release i guess.
I would love to help, if i had any knowledge in programming or interfacing.
MRXTCZ
its restrictive on what you can use to pair with it. to get around this you have to use a $90 dongle... kind of a fuckaround, and you still have a lag at the end of it. I've started working on a serial port emulation which runs on a jailbroken phone... but you'll need to jailbreak your phone first to use it.
Found this, not sure if you have already?
http://www.devtoaster.com/products/rev/
forgive my iphone ignorance, do they have a mini usb connector?
i've got a hacked navman, and seen some other examples with cool
interfaces that hook up to obdii via the mini usb.
think people have been doing similar thing on one of the palm pilots linked via some other device.
Edited by Stagea_Neo
nope.... proprietory connector, the supplied USB to iPhone connector cable can be used to connect the iphone to your PC, and access it as a camera... or with the itunes drivers installed you can access it thru itunes... or if you put it into recovery mode you can read and write from the firmware.
I was thinking something along these lines in the supplied link, wonder if you could rig up something to talk to the iphone via the proprietory usb cable to consult port.
http://www.blazt.biz/products/images/usb_cd_large.JPG
well all that does is send a regular RX/TX serial signal using the USB port. You can wire up an iphone to send and recieve this signal (uding the proprietory plug instead of the USB plug), but that level of interaction is not allowed using the factory software, you need to bypass the operating system and talk to the port directly... which you can only do in a jailbroken iphone.
and the usb would only be usb client, ie the iphone is a usb device to the PC, rather than a usb host, as in the iphone can use other usb devices like the usb consult cable.
but thats irrelevant given theres no drivers for the iphone for that usb chip (ftdi)
Not sure if you need these or not, had them in my bookmarks at work.
AppleScript Documentation
http://developer.apple.com/documentation/
welcome to macscripter.net | applescript and script resource
http://www.macscripter.net/
Apple - Software - AppleScript
http://www.apple.com/applescript/
ScriptWeb - Macintosh Scripting Resources - Since 1995
http://www.scriptweb.org/
Scripting Information
http://www.latenightsw.com/scripting.html
  • 2 years later...
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
