Hi guys.
Today i had my Stagea on dyno again, at 1,49 bars boost.
Before it was on the dyno, we adjusted the ignition 4 degress higher in the boost-area, air-fuel-ratio at 1.55 bar on road, 11.8
Effect on dyno: 552 hp - 588 nm.
Engine insite, everything standard, cams, valves, gaskets, bolts, pistons, beams ect.
Changed:
Aftermarked intake-plenum, 80 mm trottlebody.
Injectors, 680cc.
Single turbo manifold.
Turbo T70.
Aftermarked ECU, Megasquirt, adjusted by my self.
Aftermarked Intercooler and piping, 2,½ inc, to 3,½ inc.
Exhaust 3,½ inc all the way.
Innovative Motorsport LC1 wideband kit.
Excity cintermetal clutch.
Video and dyno result.
Dyno:
http://www.112-video.dk/images/articles/Dyno.jpg
Edited by Stagea Denmark
https://www.sau.com.au/forums/topic/238036-danish-stagea-on-dyno/
Hi guys.
Changed:
Injectors, 680cc.
Turbo T70.
Dyno:
Impressive! Is this with a RB25DET or a RB30 block with RB25 head?
Thats a mega hair dryer there!! whats the lag like on the road?? i wouldn't expect the standard internals to last too long with that much pressure... but good job mate looks tough 2
thanks.
I get boost a 4300 rpm, yes all the internal parts will last much longer, because i get my boost at high rpm, often when people broke there h-beams, is when they get boost at low rpm, i think thats the reasons i can get all that power, i will try to go for 600 hp now, i get a lot of wheelspin when i get boost in first gear, and second gear it just pull, no tire smoke.
Octan 99 from Shell. (i will have to take a look at the ECU-sheet to tell you that, but it is high (later today)
The car i rwd, and this is a normal RB25DET engine.
Take a look at this video, and watch where the light starts in the manifold, cylinder 5 and 6, there we have added more fuel, to cool them.
On this video,. i make 1,3 bars boost, and approx 470-480 hp.
thanks.
Well how good is that WELL done,I have raced Nissans for nearly 40 years now , thats impressive
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
