i have oil leaking from the bolt closest to the fire wall on the exhaust manifold. I recently used an easy-out to remove the previous broken bolt and since replacing it with a new one oil has been pissing out.
any one got a clue on what ive done and how to fix it?? any ideas appreciated!
https://www.sau.com.au/forums/topic/23804-help-oil-leaking-from-bolt/
the bolt is definately the right size and in nice and tight. Im unsure whether it had a copper washer as the stud was broken since i had the car. Should there be oil in this area of the engine in the first place?
the bolt that i have used has a washer but does not completely cover the hole on the manifold like the others do. But i am still unsure why there is oil coming out as i think there shouldnt be oil there in the first place. Maybe i have damaged the exhaust gasket but no oil is seaping around the gasket only from the bolt hole.
thanx for your help
there is no oil in the exhaust manifold dude , it must be leaking from somewhere else like rocker cover .theonly thing that comes out of the ex manifold is exhaust so if it was leaking there would be black around it .when u drilled the bolt to install u r easyout did u drill to far in to the head maybe ?if u did that may explain the oil . pull the bolt out and blow compressed air in the hole to see if it goes in to the head if it does thats u r prob , if it doesnt look elsewhere for the oil leak.
as far as i remember that should be a stud in to the head and a stainles nut with a thick washer , the washer is there so the nut can be tightened and cause the hole in the manifold is big so the man is easy to install .people brake these studs cause they do them to tight, u should use a torque rench to do them up and start from the middle and work ur way to the outer nuts otherwise u may warp the manifold .when u undo them u undo the outer ones first and work u r way to the middle .
there was oil leaking from the broken stud before hand thats why i decided to replace the stud, but no were as much as it is now. The rocket cover isnt leaking the oil is deffinately coming through the the manifold hole where the bolt is. I must of drilled into the head or some thing god damn hope its an easy fix for ats
take that bolt out then ,clean all the oil from that area if u dont have compressed air try to fit a tube in the hole and fix it somehow so it doesnt leak ( the tube ) blow or suck at the other end of the tube if air flows u drilled to far into the cil head and oil works its way through the thread ,if thats the case get some locktite put it on the tread of the bolt u are using ( i hope its stainless otherwise u wont be able to get out in say 1 years time ) then screw the bolt back in wait for the locktite to harden say 1 hour and it would probably fix your prob.
when u pull the bolt out put a very thin screwdriver ( thiner then the drill u used ) in the hole if it goes in a long way u drilled to far in .
if thats what the problem is it should work .if u have to buy the locktite get the red one for studs a cant remember the number of hand , just ask for studs and its red not blue .by the way its not cheap either like $20 for a little bottle but u only need a very small amount . i hope it works for u .
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
