ok i went out saturday nite .. and came home to this .
my parents didnt call me because they know how up set ill be etc .
my car was locked and parked in front of my house with a silent alarm and imobaliser.
there is no damage to the door locks ..and no cut wires they even had some sorta key etc to try start the dam thing .
the culprits were disturbed when my parents herd my cars trying to start .
found 8 or more abbos in two cars one r33 and one wrx .
if ayone know of aything pm me etc
as i now have no car or job to get to .
THANKX to the scum
https://www.sau.com.au/forums/topic/238052-a-holes-in-adel/
  • Replies 75
  d-- said:
that's really bad mate.
Hate to be stereotypical, but aboriginals who drive WRX's and R33's usually wouldn't be the type to attempt to steal another car.
do you have a suburb this was done in?
feel for ya man :S
Unless they stole the 33 and the wrx also which isn't too hard to imagine.
https://www.sau.com.au/forums/topic/238052-a-holes-in-adel/#findComment-4162383
Yeah i would agree
having known a lot of low life in my time its what they do
steal car A then drive around till they see car B keep trying till they get more or get into a high speed 99% of thefts aren't targeted just random drive by's
https://www.sau.com.au/forums/topic/238052-a-holes-in-adel/#findComment-4162425
really sorry to hear of this mate
i can understand how upset people get when their pride and joy has been messed up
I dare say that they WRX and the R33 were both stolen as well
this is getting really bad
just as bad as it was at the beginning of the year
https://www.sau.com.au/forums/topic/238052-a-holes-in-adel/#findComment-4162522
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
