I'm not driving the car much on the street anymore- suspension is too harsh, exhaust too loud etc. for it to be very comfortable to drive. Just going to use it for the odd trackday, so not concerned about drivability anymore. If I was, I wouldn't remove the 2530 :)
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/4/#findComment-433868
  • Replies 99
ok, i might be opening up a can of beans that'll spill into what should be another thread but........ what would be cheaper, if you wanted to have a weekend car, and a track day car..... a worked gts-t, or a worked gt-r, both having say...... 600hp at the engine? or would there be too many variables involved? just running on my train of thought here
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/4/#findComment-434569
Hah now that question deserves a long, opinionated answer...
Depends on size of budget (is $5,000 cheap or is $30,000 cheap?), driving style, access to facilities or contacts, maintenance budget etc. etc. You could write a book on it (I'm sure someone has).
Bottom line (in my humble opinion, and stated a million times in other posts)..
* GT-R's cost more initially, increasing performance costs less, marginally higher upkeep
and the inverse for GTS-Ts. Get a 180sx - cheap to buy, cheap to improve performance, cheap to maintain.
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/4/#findComment-434575
Kinda got sidetracked - as for some dyno figures...
Rick Shaw has a 2540 on his personal car (it's up for sale btw, as you would expect it's immaculate and everything has been rebuilt) and has dyno'd ~230kw at his shop. That was at 1 bar boost - his standard fuel system limited this.
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/4/#findComment-434672
Ezekrael
as far as clutch choice goes, a search should reveal all the info you need.
for around 900 fitted got me my extreme single plate ceramic button clutch with sprung centre. many members are using this clutch and its very usable. I think its good for 450hp, which means it should be fine unless you upgrade your turbo again and shoot for over 250rwkw.. then again whatsisname has over 250rwkw and that was his clutch choice too.
evo- fuel pumps are INTERNAL on 33's and yes can still hear buzzing. No std turbo not good for 230rwkw.
for HKS relevance heres my GT2530. i am assured by the supplier (a friend of a friend, who is the friend of the guy who bought the turbo new in japan!) that this turbo has done less than 2000km's in japan, cost me 1800bucks. Took it to ATS for inspection and they confirmed its perfect.
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/4/#findComment-434710
SLY 33, how loud is your 044?
- mine I can only just hear it with the ignition on but engine switched off. I have a nismo exhaust with dual muffler so it just purrs at idle, but I cant hear the pump at all.
I wouldnt be in a hurry with the extreme clutch - mine was good for about 6 months then it started dying. I know a couple of other guys who had problems running just over 300rwhp.
I ended upgrading to a os giken twin, wish I had gone that way in the first place.
Nice score on the turbo by the way, you'd have to be happy:)
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/4/#findComment-434911
the buzings not that loud but when the exh isnt booming i can hear it. During summer when it gets warm the buzz gets quite loud.
Apparently the extreme clutch doesnt like to be slipped, when i got mine i was told that if i tried to slip it each take off it wouldnt last long, and to just let it out and it would be fine. ive had mine about 6 months, lots and lots of launches, no troubles yet...
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/4/#findComment-435061
Steve: The one pictured is a 52T, but I also have a 56T trim. Actually, the one pictured is damaged (turbine wheel) but I hope to get it repaired soon, if it can be repaired. The 56T I used on my EVO4...how can you tell if it's the current or older model???
What's the difference with your turbo? Do you have a pic?
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/4/#findComment-435573
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
