Summary:
Make:1993 Nissan Skyline HCR32 GTS-t
Milage:210,xxx kms
Transmission: Manual
Colour: Black
Complied? Yes
RWC supplied? Negotiable
Currently registered? Yes, currently til December 12 2008. If not sold before the next notification comes, it will be renewed to 2009
Price: $9000
Contact: Shane - Mobile: 0438 733 038 Email: [email protected]
Details
Owned it for almost 5 years as my loyal daily driver (hence the high kms), selling as I've bought a R32 GTR
Serviced every 5000km using synthetic oils, always sheltered. Paint has deteriorated in some places, but all panels are straight (see pics)
Engine passed a recent compression test, and sounds and feels alot more solid and durable than the odometer would lead you to believe. In my time of ownership the only things to have failed on it are the fuel pump and the clutch, both replaced with the same items that were in the car already.
Mechanical Modifications:
3" front pipe from the dump pipe to cat, 3.5" cat back exhaust
Front mount intercooler kit
Bosch fuel pump
R33 GTS gearbox
Exedy heavy duty clutch
Upgraded shocks / springs (unsure of exact setup but it is definitely stiffer than a regular GTS-t)
Front and rear strut braces
Slotted front rotors
Wheels:
17x8 (Front) / 17x9 (Rear) Kosei mesh design rims - fairly decent gutter rash. Been on the car since it landed from Japan over 7 years ago.
Tyres:
225/45ZR17 Goodyear Eagle F1 GS-D3 (front) and 235/45ZR17 Hankook K110 (rear)
Stereo:
Pioneer CD/MP3/OEL head unit
Pioneer 6 CD stacker
JL Audio 6" splits (front)
JL Audio 6"x9" speakers (rear)
Rockford Fosgate Punch P2 12" 250W RMS sub in box
Audioline 4 ch amp (powering speakers)
Rockford Fosgate 2ch bridged amp (powering sub)
Misc:
Cyclops Paralyser P385T alarm + 2 point immobiliser + tilt / shock sensors
Apexi Boost Gauge
Fire extinguisher
Last dynoed at 139rwkw @ 12psi with the stock intercooler and stock front pipe. Ran a 14.7 @ 95mph in this same trim back in October 2004 at Calder Raceway.
$9000ono, more with RWC. Price is negotiable, reasonable offers welcomed.
Located in Vermont South, Melbourne.
Contact Shane
0438 733 038
or
[email protected]
Pictures
The tape is from a recently fitted windscreen, just got the car back then and took these photos quickly before it got dark
Exterior
Interior
Boot / Stereo
Engine Bay (could use a clean...)
Genuine enquiries only, thanks.
Edited by Master Boxhead
  • 1 month later...
  • 3 weeks later...
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
