Briefly you can get some of the same cartridges or center sections used by HKS in their "GT2835" turbos .
These use a cropped or ground down in size Garrett GT30 turbine , but only HKS had proper turbine housings made for the cropped turbine . The versions Garrett market use the wrong family of turbine housing (GT28 rather than GT30) and not surprisingly the results are very ordinary .
HKS use an older turbo number description system and parts of it are just plain wrong .
1) There is NOTHING GT28 about the turbine in a "GT2835"
2) The "35" bit means GT35 series 71mm compressor wheel .
The current Garrett numbering system describes a "GT2835" as a GT3071R , GT30 meaning GT30 series turbine and 71 meaning 71mm compressor .
The later system doesn't differentiate between cropped or std GT30 turbines , it assumes the buyer knows which one they want and order it by part number .
A VERY important thing to note is that Garrett don't make a T3 flanged turbine housing for the cropped GT30 turbine , technically only HKS have them on their GT2835 Pro S RB20/25 bolt on turbos .
If you could find one of their turbine housings you could fit it to a Garrett marketed version but it's not the same because HKS's compressor housing is different as well - designed to work together as a complete package .
Bottom line , HKS designs engine specific turbo options where Garrett markets generic units .
Cheers A .
https://www.sau.com.au/forums/topic/238136-turbo-choice/#findComment-4163772
