Pod v's Stock Air Box Temperature Results
Guest Robo's
I planted the temperature probe between the AFM and the turbo.
With the stock airbox, stock over radiator duct and another 1 1/2 inch duct, temperature was very stable driving from traffic light to traffic light. After the car sitting, the temperature rose somewhat (say 20 degrees) this is after a couple of hours of being parked, and was slower to move down, i guess this is heat soak.
Now just installed the pod today, and at first notice the temperatures fluctuated alot. On a cold cruise, it was nearly as cold as the stocky, but as soon as your stopped, you could watch the thermomoter rise very quickly. But then it would cool quickly too as you start driving but still not as cold as the box.
I will continue with the POD for a few days and experiment a bit more.
Some more testing with the POD
1) POD only matches the stock air box on the open freeway, 100+
2) Any slight slow down and the POD gets warmer, usually about 5 degrees.
3) POD's temperature rises straight away at the traffic lights, upto 5 degrees at one set of lights, Air Box will rise approx 1 degree.
4) In traffic it took the stock air box to rize to 30 degrees in about 20 minutes, POD was at 30 degrees in 3/4 minutes.
5)This is funny, travelling on the freeway with 2 quick bursts in 3rd, saw the pod rise 5 degrees.
Whether these tests do anything to performance or not is a different story, well for me the stock air box is on.
Originally posted by 2fardown
I took off my HKS pod and replaced it with the stock airbox and a K&N panel filter on the weekend.  I honestly found it difficult to notice the difference between the two.
Surely you must've noticed an increase in bottom end torque (below boost)? When I replaced my pod for a K&N panel the car also became more responsive, for example, the boost guage needle jumps when you punch it.
Its also good to have the exhaust note back! Induction noise is annoying!
My 2c: pods are a waste of money unless you have a CAI.
Originally posted by fattdex
Have you made an airbox around the pod, or is it just stuck in the general position of the stockie with no shielding??
No shielding, although the standard cold air duct was still attached. Even if it was shielded, i just cannot see any cold air getting in there, so eventually its going to heat soak.
I think what it comes down to is what your looking for.. if u want that extra go down low the the air box with a good filter and some CAI would be the go.. but for that extra bit up top maybe the pod with a heatshield and CAI would do the trick? I think i'd prefer to have real nice mid/top range power because when ya want to go fast your at 80km/h real fast anyway and u still gotta hit that limmiter:P
I have gatehred some information from various people on this it doesn't solve much but brings some things to light.
"u do loose a bit of power down low but the power gain that i got topend with the pod was much better, but i think a properly set up air box with cold air running to it and a proper panel filter would probably be better. "
"POD's are a good investment for the mid-topend performance, but to be effective down low they need to be sealed correctly."
I've done tests with a pod filter and partition with the stock air duct feeding into the partitioned space. I'll post results like Robo's did:
1) the temps stablise at 60+ even in heavy traffic (not 100)
2) pod does get warmer by 5deg when you slow down a bit. but cools down again, as long as your over 60km/h
3) POD's temperature rises straight away at the traffic lights by a massive 25deg. on idle for 3 minutes, not 5deg. it took 7 minutes of driving at 70km/h to lose the heat soak.
5) travelling on the freeway with 2 quick bursts in 3rd, saw the pod drop by 3deg., not rise 5deg. Driving on full boost saw the pod actually drop in temp.
I think the important test is plenum and intercooler temps (actual intake temps), not pod temp.
This was done on stock boost, stock intercooler, 3" turbo back exhaust. (R33)
-rb25
I'm thinking to add a little bit of heat shielding on the factory air box, especially the bottom part of the airbxo where it may collect heat from the engine bay faster. Anyone recommend a good heat insulator that is easy to apply?
I reckon with heat insulation and a hi flow panel filter like K&N or Blitz Sus or Apexi, the factory airbox will give excellent cold air feed to the turbine & engine!
ARC made a box induction kit. Blitz also have similar one, so you'll get the quiet intake operation with higher flow airbox. Not sure if you can put the factory inlet duct over those induction box, so it's not just an open panel that sucks hot air from the engine bay...
I've had my car on the dyno making 164rwkw on 1 bar of boost.
We removed the stock airbox and stock air filter and slapped a K&N Pod filter in there. The bonnet was open and there was no heat soak. The K&N made absolutly no power gain any where in the rev range, there also was no loss either.
Since then I've adapted a 100mm CAI from the inner guard in to the stock air box. I used 2 x 45degree PVC bends. One facing forward in the inner guard and the other on top facing in to the stock air box.
I then grabbed some plastic painted it black and use silicon to attach it to the side of the air box to give it a flush stock look.
Its heaps noisy now. I've driven through big puddles etc and checked the air filter. Not once has the filter been soaked. You get the usual slight mist however that cannot be helped.
With the 45degree bend in the inner guard it is slightly off centre so it doesn't get a big gulp of water rather it deflects off it slightly.
I'd love to see how pod performs on dyno with bonnet close.
Most cars when dyno-ed they have their bonnets up, I know u need to run a pressure sensor from dyno to the engine, but will tuning be more street accurate with bonnet just down? Even if the bonnet not fastened, just lying shut.
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
