i was driving in stage 1.. and i stopped down to 2k's there was no car, no stop sign, no give way sign, n he sed turn right. i accelerated and turned right and then a ferrari comes driving past and he sed it was too close. pull over n i failed.
the guy was a f**king flamin mongrel too.
fkn scumbag cost me $200
($150 for my driving instructors car)
f**k VicRoad faggots =\
https://www.sau.com.au/forums/topic/238178-failed-ps-driving-test/
Not to worry...
Should be OK next time - but hey, you've been told that already by how many?
Went thru a STOP sign on my 1st go.
Besides, I hear that...
there's a f**king flamin mongrel driving inspector around Vic somewhere & his Ferrari is being driven by his g/f
(This is 11-12 odd years ago now so I am not sure if you can still do it.)
My instructor came along for the ride on my P's test and sat in the back seat. He was well known by most of the examiners in the area. It just so happened he knew the examiner I got and they proceeded to spend the whole test gas-bagging to each other. I don't think the examiner gave a shit if I did the right thing or not. Try that! Works everytime.
i remember my test, i passed first time, it was a breaze, i guess im just an ace driver. :D
+1
L's = passed first go
red P's= ^
greens= ^
Full = ^
my reds was piss easy, 15 mins max and did the reverse park, parallel and 3 point.
The $200 must've been a bit of a sting, but you'll know what to expect for next time. Good luck! :down:
The way i see it is , Ok you have to get your red p's well...lets just get into the car and drive like an 80 year old retired baker.Once you get it what can they do , you can drive how you want to.In short form just drive like that and you will be a sure pass.
We never had anything like that.
Drove to town picked up the local copper, went for a drive. He asked how far I’d stop from a rail crossing. I said 500m. Why so far? To be on the safe side I said. Did a hill start. He said you didn’t use the handbrake. I said didn’t need to. He got out; put a bit of chalk behind the wheel. Now do it and if you crush the chalk you fail. Didn’t crush the chalk.
OK now what about my tractor licence? Where’s the tractor. On the farm, wanna go see? No she’s right.
How about my semi licence. Where’s the semi? Just stop that one (one of Dad’s).
Got in and went for a drive. These things are big he says, never been in one before. Can you reverse up that street? No worries, back it up, tear the bitumen to bits turning the tri-axle.
Shit, didn’t know it would do that, let’s go back to the station.
All good he says, just remember you can’t drive any better today because you’ve now got a licence than you could yesterday.
True.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
