Hi Everyone,
I need your help, I have an r34 Skyline and some warning lights have come on the dash. They state HICAS, TCS OFF, SLIP and the Engine Light Symbol.
How can I fix this problem? What is the reason behind it?
Any help is greatly appreciated.
Kind Regards,
Dave
is it always on? like does it stay on all the time? or when you turn off your car and turn it back on does it dissappear?
if it stays on its best just to take it to a work shop asap.
My mates one happened like that awhile ago, turns on then when she turned off her car and turned it back on, its all off..
Edited by viet_boi
The HICAS, TCS OFF, SLIP and the Engine Light Symbol on my dash are lit up like a Christmas tree always... It's normal, just leave it :P And if it really gets you paranoid, take the dash out n remove the globe (why spend hundreds finding problems when you can just "cover them up") :miner:
In all seriousness, I wouldn't be too concerned... I'm not :down:
EDIT: Can provide photo evidence if you're in disbelief...
Yeah after reading the post above... prob not best to take my advice :) My car runs perfectly fine with those lights on, reasons will be a little different to yours.
HICAS - has been removed
TCS OFF - doesn't have TCS stuff anymore
SLIP - can't be slipping if it doesn't have TCS
Engine Light - I'd like to say it's only because of the missing AFM, but I'm pretty sure it's complaining about other stuff missing too...
this is just a guess but I would say a speed sensor
thats the common component of tcs and hicas
get someone to put it on a diagnostic and see what error code you get
i agree
mine did the same when i first got ma car
took it to the place i got ma car n ran a diagnostic n they jsut said one of the sensors were playin up n they just had to adjust s umthin n ever since then light hasnt' come on since:)
I start my car and the HICAS light is always on no matter what. The other lights (TCS OFF, SLIP and Engine) come on about 5 minutes into driving and then stay on until I turn my car off. If I leave the car for a short period and then start it up again, it only takes another 5 minutes for the lights to come back on even if the car is just idling. I don't thrash the car at all so i'm pretty devo and confused as to what is going wrong.
So far the next steps are to take the car in to a workshop and get them to look at the computer error diagnostics and go from there and to replace the coils with Splitfires as well as upgrade the spark plugs.
Does anyone have any other ideas? If this has happened to you or someone you know and you found out how to fix it can you please let me know ASAP, it would be much appreciated.
Kind Regards,
Davey
HICAS, the motor is probably screwed in the assembly... before you get too upset, undo the plug, spray it with contact cleaner n see if it works. If not, who cares - buy a $100 lock bar, put it in, and take out the globe (fixed - will actually improve the car)
TCS n SLIP, this is a bit of a rough one as it can light up for a few reasons... again, pull the plugs off the TCS motor n clean them. Then crawl under all 4 wheels (maybe just rear 2 I think) and make sure the wheel speed sensors are plugged in. Not having them plugged in will send the ECU crazy thinking your driving on a sheet of ice or something.
Engine light, your guess is as good as mine here... but all the essentials that would trigger it (AFM, Coilpacks, Factory Boost Sensor, Knock Sensors, Oil Level). As mentioned earlier, my light came on when we removed half the factory sensors (no use for them) - can't really help with this one. Although, I think you'd be able to use a process of elimination here (AFM shot = car run like poo, Coilpacks shot = car run like poo, Boost Sensor = irrelevant with aftermarket ECU, Engine Oil = check dipstick, Knock Sensors = dunno how to test sorry, assuming voltage output)
Hey, thanks satanic, your thoughts are greatly appreciated. I will check it all out.
Thanks
Dave
  • 4 weeks later...
I drove from Nowra on the NSW south coast to the north coast the other day and first the hicas light came on then the abs and then all the orange lights came on and then the speedo got stuck on 90 kmh and the tacho got stuk also and the the odometer disapeared and stayed like that even after the car was turned off and the speedo and tachco did not go down straight away but was down a cupple of hours later when i came back to the car but the hicas came back on when i started the car but it went away after being left for the night and drove it for a hour and nothing came up today .
Id say its your coils, if your coils are screwing up or you get dodgy ones installed; all those lights will be thrown up (at least in my experience). I Bought some DIS ignition coils for my 34 when my old ones died, turns out i got a dodgy batch and all those lights were thrown up lol. Once i put the new replacement ones in the lights went out, the car also ran a lot smoother when shifting. If after trying satanics suggestion the problem isnt fixed my money would be on the coils. Get splitfire or DIS, Splitfire have a better name but DIS are cheaper and i cant really tell the difference between my coils and the splitfires in a mates 34.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
