basically i am selling my car and a guy came and had a look and was worried about a bit of oil on the block (comes from leaking rocker cover gasket, same as what skylines suffer from) and he wants to do some tests on it to make sure the head gasket isn't gone. now i know you can do a pressure test, and a compression test (but neither will tell you if the head is leaking oil due to the head gasket). i explained that to him but he said that his mate has a few testers that don't require removing anything.
what could they be?
i was talking to my mate who is a mechanic and the only thing he could think of a TK test, but again that won't tell if the headgasket is the cause of the oil leak. an oil pressure test probably won't show it either if it is a tiny little leak (but as i said it's the rocker cover gasket leaking and i told the guy that). the only thing we could think of is that this guys mate has a crystal ball, or is a psychic.
so any ideas on what this guy is on about?
https://www.sau.com.au/forums/topic/238249-engine-tests-what-sorts-are-there/
the only ones that wouldn't really require anything being removed would be compression and leak down afaik.
or he is trying to blow something minor out of proportion to try and hammer the price down.
Edited by TiTAN
both compression and leak down require getting to all cylinders, which means removing the manifold to get to the rear 3 cylinders in this case. which i told him i wasn't keen on doing because it takes a few hours to remove and install the manifold, and if the gasket gets damaged i have to get a new one of them also.
and none of them are going to able to really tell you if the head gasket is causing the oil on the side of the block (which is why this kid - he's only about 19, wants to do the tests). he just really doesn't seem to know what he is on about. and is getting advice from his mates who also don't seem to know too much.
as for trying to get the price lower, that isn't going to happen. and he has told me that many times he is keen, so why should i lower the price? if he didn't think the price was reasonable he wouldn't be saying that he is keen to get the car in every second message.
There are no other tests he can do other than the ones mentioned above. The oil won't be coming from the head gasket. Change the RC gaskets and clean the oil down. Drive it for a couple of days and see if the oil re-appears.
I think he maybe made a comment without thinking about it and is now trying to backpeddle via bullshit. Call his bluff, tell him you know he is full of shit, there is no test that can tell you where the oil is coming from.
Fix the highest leak...clean down...and re-check.
the rocker cover gaskets were replaced before i bought the car (to pass the roadworthy) but the new ones only stopped the leak for about 2 months.
oddly enough he didn't show up last night. on monday night i explained to him that neither a compression test nor a pressure test would show the leak and explained why, and i said i wasn't going to let him do a compression test due to the work involved removing the manifold. and that's when he said his mate had these other testers that didn't involve removing anything, to which i replied that i was interested to see what the testers were.
so i think he was going to try and do a pressure test, etc and tell me that the results were bad and when he found out i know what i'm doing he has had second thoughts.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
