Make:Nissan 1999
Model: stagea
Milage: 61,xxx
Transmission: 4 spd auto tiptronic
Colour: bayside blue (was sonic silver painted in japan)
Complied? yes
RWC supplied? no
Currently registered? yes
Price: 20,000
Contact: 0423878375 (sms only please work odd hours and shift work)
Comments / Modifications:
1999 Bayside blue was painted in japan before import was origanally silver everything painted except enginebay and numberplate cutout on rear tailgate :)
4 spd tiptronic auto with aftermarket cooler and shift kit (I think ? holds gear way to long to be stock and shifts hard)
hks intercooler and piping
hks cat back exhaust
hks foam air filter
turbotech boost controller running 12psi made 176rwkw@chasers dyno
260rs front bar with masa sideskirts and rear bar
blitz bov
Dayz edition carbonfibre interior inserts in dash and doors (also have a full spare set of door inserts that are carbonfibre also)
kenwood ipod ready head unit with standard speakers and tweeters in rear doors
Interior immaculate black and grey cloth including full set of origanal stagea floormats.
Origanal stagea strut brace
Intensive 18inch rims with nankang tyres near 80%
Full privacy tint on all rear windows
Twin sunroofs
Tein adjustable coilovers
The not so good has small crack,stone chip and scraping on front bar,one scratch about 5 cm long on rear bar(touched up by previous owner),crack in rear bar on both rear arches
Car has only done 4000km's since being bought in by me the first AUS owner.
Maybe interested in swap for non drifted 180sx/200sx/silvia (sr20det)or clean r32 must involve cash my way.
This is Expression of interest only at this stage as im still undecided if i have to sell it or not, with a new baby coming and one wage cash is getting tight.
Images:
Edited by AndyD
https://www.sau.com.au/forums/topic/238260-eoi-1999-nissan-stagea/
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
