Age: 12 y.o
Condition: All parts are in working order
Contact: PM with any questions
Comments: Very neg. on prices.
If you want any more pictures just ask.
I'll have to upload more pictures tomorrow, as most of the pictures i have are over 2MB and wont upload.
Series 1.5 Differential Cradle w/ Diff & Hicas Rack (ABS) - $500ono++
Series 1.5 Stub Axles w/ Lower Control Arms - $200ono++
Series 1.5 Front Struts - $100ono
Series 1.5 Steering Rack - $100ono
Series 1.5 ABS Unit - $50ono
Series 1.5 Window Washer Bottle - $20ono
Series 1.5 Overflow Bottle - $20ono
Series 1.5 Brake Booster - $100ono
Series 1.5 Passenger Side Window Switch - $10ono
Series 1.5 Passenger Side Mirror (White) - $50ono
Series 1.5 Front Windscreen Wiper Arms - $20ono
Series 1.5 Front Windscreen Wiper Motor - $20ono
Series 1.5 Rear Brake Caliper (Side Unknown) - $50ono
Series 1.5 Rear Brake Rotors - $50ono
Series 1.5 Pedal Assembly (Clutch, Brake & Accelerator w/ Throttle Cable) - $50ono
https://www.sau.com.au/forums/topic/238267-r33-gts-t-parts/
Age: 13 y.o
Series 1 Side Skirts - $150ono
Series 1 Side Mount Intercooler - $50ono
Series 1 Standard Turbo w/ Lines - $300ono
Series 1 Turbo Heat Shield - $20ono
Series 1 Standard Fuel Pump x 2 - $50ono each
Series 1 Standard Fuel Pressure Regulator - $20ono
Series 1 Standard BOV - $20ono
Series 1 Engine Fan - $50ono
Series 1 Rear Spoiler - $50ono
Series 1 Dump Pipe - $50ono
Series 1 Valley Cover - $20ono
Series 1 Air Intake Pipe - $20ono
Series 1 Air Snorkel - $10ono
Series 1 Ohlins Rear Struts w/ Dampening Adjustments & Springs - $200ono (Fronts available but are useless)
https://www.sau.com.au/forums/topic/238267-r33-gts-t-parts/#findComment-4165569
moonus - sorry mate, dont have any rear quater glasses
G0DZLR - ill take some pictures of it today and pm you. i dunno if they are M-Spec all i know is they are from a Series 1 GTS-T
https://www.sau.com.au/forums/topic/238267-r33-gts-t-parts/#findComment-4210456
Series 1.5 Stub Axles have now been stripped apart.
**New Parts**
Series 1.5 Front Lower Control Arms - **Sold pending payment**
Series 1.5 Front Upper Control Arms - $50ono
Series 1.5 Front Castor Rods - $50ono
Series 1.5 Front Wishbones - $50ono
Series 1.5 Front Brake Hubs w/ Lines - $100ono
Series 1 Inlet Manifold - $50ono
Series 1 Throttle Body - $50ono
GTR Series 3 Genuine Nissan Front Bar Indicators - $50ono
Pictures will be up tomorrow.
Feel free to make an offer :D
https://www.sau.com.au/forums/topic/238267-r33-gts-t-parts/#findComment-4223596
Just found out they are NOT GENUINE NISSAN Indicators....
They are just copies. :)
phatlavish - thanks mate, ill check that up :O
https://www.sau.com.au/forums/topic/238267-r33-gts-t-parts/#findComment-4226502
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
