Item: PYTHON 902 car alarm, lcd remote ect
Item Condition: brand new still in box
Reason for Selling: not needed on project anymore
Price and Payment Conditions: bought for $600 sell for $350, will post at buyers exspense.
OPEN TO ALL OFFERS, THROW ME SOME
Features
Overview: The Python car security system from Directed Electronics will protect your vehicle with the most up-to-date electronic technologies available, including the Responder 2-way remote control, Stinger DoubleGuard shock sensor, the Revenger six-tone siren, and the Failsafe Starter Kill. The system has a total of 5 auxiliary outputs to provide keyless entry and other most-requested convenience features. The unit is covered by a limited lifetime warranty.
Responder 2-way Remote Control: The Model 902 comes with one Responder 2-way 4-button remote control with an LCD display. The Responder remote gives you confirmation of all commands virtually instantly with easy-to-understand icons and text. It also alerts you to security system triggers by beeping or vibrating when out of audible range of the siren. The Responder remote is powered by a single "AAA" battery. In addition to the Responder remote, the unit also comes with a standard 4-button remote. To enhance the range of the remote controls, a separate plug-in antenna is included with the alarm. The working range of the system is approximately 1/4 mile. The 4 buttons fully control the following features and functions of the security system:
Lock Button: controls the Lock-Arm/Panic On/Panic Off functions.
Unlock Button: controls the Unlock-Disarm/Panic Off functions.
AUX Button: controls Silent Mode and Auxiliary Output 2 (typically trunk release).
Red "Asterisk" Button: controls the Panic On/Off functions.
Button Combinations: combining two buttons together will control Auxiliary Outputs 3 through 6.
ESP2: The Model 902 features ESP2, Directed's exclusive serial communications protocol that allows extra ultra security, high-speed communication between systems, and enables many of Directed's key features.
Clone-Safe Code-Hopping: To prevent the unauthorized cloning of the remote's transmitter, the receiver and remote controls each use mathematical algorithms to change their codes each time the remote is used. The control unit knows what the next codes should be, even if you use the remote control out of range of the vehicle or the battery has been removed. Should the remote and control unit ever get "out of sync", you can easily re-sync the remote by pressing the "lock" button several times within range of the vehicle.
Multi-Level Security Arming: Multi-Level Security Arming allows you to select which of the system's inputs or sensors will be active and which will be bypassed at the time the system is armed. Multi-level security arming applies only to a single arming cycle. Once the system is disarmed and re-armed, all zones will be active again.
Failsafe Starter Kill: To prevent your vehicle from being stolen, the control unit has a built-in relay which will disable the starter. The Automatic Engine Disable (AED) feature, when programmed "on," disables the starter 30 seconds after the ignition is turned off. To start the car, it will be necessary to disarm the system with the remote control. The included starter immobilizer harness can be installed in a normally open or normally closed starter circuit.
Revenger Siren: The Model 902 includes the Revenger Soft Chirp siren (model 514N). It consists of six different tones in sequence. Any of the tones can be eliminated, resulting in a unique, easily identifiable siren sound. The siren chirps can be either full volume or six decibels quieter than the full alarm blast.
Stinger Double-Guard Shock Sensor: The system features the Stinger Double-Guard Shock Sensor, which is designed to pick up impacts to the vehicle or glass. The sensitivity of the shock sensor is adjustable between level 0 and 20 using the remote control. When the sensitivity is set, a light impact will generate the "Warn-Away" pre-warning chirp of the siren. A harder impact will trigger a full alarm blast.
Auxiliary Outputs: Convenience options, such as remote control trunk release and window automation, are available through the system's five auxiliary outputs. The Channel 2 output (typically trunk release) is triggered using the AUX button on the remote. The Channel 3 through 6 outputs can be activated by pressing a combination of buttons simultaneously.
Silent Mode: The Silent Mode allows you to temporarily turn off the arm or disarm chirps. When in the Silent Mode, the Warn Away response to lighter impacts is bypassed, however, the alarm remains fully capable of triggering a full alarm.
LED Status Indicator: The alarm includes a bright blue LED which plugs into the control unit and indicates the status of the system. It can also report triggers and faults in the system or sensors. Mounting the LED requires drilling a 9/32" hole.
Power Door Locks: The system has door lock relays on-board, and can directly interface with most electric power door lock systems drawing 30 amps or less. If additional door lock relays are required, the 607451M plug-in door lock relay module can be added.
Dome Light Control: You can control your vehicle's dome light in a number of ways:
Security Only: The dome light activates for 30 seconds after the system is disarmed.
Ignition Controlled: The dome light activates for 30 seconds after the ignition is turned off.
Door Controlled: The dome light activates for 30 seconds after the system sees a door has closed. (If door is held open for longer than 3 minutes, the dome light will not illuminate.
Full: The dome light activates for 30 seconds after seeing door closure, ignition, or security disarm. (This is the factory setting.)
Valet Mode: You can prevent the system from automatically arming and triggering by using the Valet Mode. This is very useful when washing the vehicle or having it serviced. In Valet Mode, the security system will not arm, even with the remote control, but all convenience features (door locks, trunk release) continue to work normally.
Nuisance Prevention Circuitry: The Nuisance Prevention Circuitry prevents annoying repetitive trigger sequences due to faulty door pin switches or environmental conditions, such as thunder, jackhammers, airport noise, etc. If the alarm triggers three times within a 60 minute period, and each time the same sensor or switch triggers the alarm, the NPC ignores, or bypasses, that sensor or switch (along with any other sensors or switches sharing the same zone) for 60 minutes.
Vehicle Recovery System (VRS): The optional VRS feature is designed to ensure that any unauthorized user of your vehicle (even if using your keys and remote control) will not be able to permanently separate you from your vehicle. After the ignition is turned on, you can arm the VRS with the remote. Once armed, the system will initiate the following sequence if any door is opened and closed:
15 Seconds after the last door has closed, the system status LED begins flashing (to give you time to distance yourself from your vehicle in the event of a carjacking).
45 Seconds later, the siren begins chirping and parking lights begin flashing.
15 Seconds after the siren chirps begin, the siren's output changes to a full blast. From this point on, when the ignition key is turned off, the VRS will immediately turn on the starter kill feature, preventing the vehicle from being restarted.
3 Minutes after the constant siren begins, the flashing parking lights and the siren will stop, and the starter kill remains active until the system is disarmed. If the door is opened or ignition is turned off and on in an attempt to restart the car, the siren and light flashing will begin again.
https://www.sau.com.au/forums/topic/238273-python-car-alarm/
hey there you said brand new still in box why didnt you use it, or has it been used in anyway? if not im interested the alarm, and posted to brisbane post 4306 how much would that be? please pm me.
