Hey mate,
Is the ashtray still for sale? If it is and its the one from the front center console near the cigarette lighter, not the one from the back.... Consider it sold.
Please let me know...
Brenton
looking for sun visors and the clips that hold them up are they clean? and what color looking for grey
how much for them posted to 4660
Cheers pm me
  • 3 weeks later...
  • 1 month later...
hey mate i need the cat oxy sensor thing that plugs into the cat converter. so you have it?? how far are you from blacktown?? will you b able to deliver to blacktown since my bro will be there christmas weekend. and also will take the sideskirts and rear pods if they are still available.. pm me.
hey champ just wondering if u still have the stock cat converter? if u do i'd luv 2 cum get it asap coz i cant drive my r33 atm from defects and im just trying 2 fix all the problems cheers mate
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
