hey guys, after a recent track day, i went to check my pneumatic boost controller and noticed the bolt in the end of the controller had actually come out and was chilling down in a crevis in the engine bay (lucky as fark), anyway put it back in and tried it in a few positions, but didnt seem to go above around 10psi which is around stock in my car, as in that is a bout what id get if i just ran a vacuum line straight to the actuator without the bleed.
now only can think of one main thing:
when the bolt has come out, a small component has come out with it, i think it has a ball bearing and spring or something in it?? this is the controller here im talking about: http://www.skylinesaustralia.com/forums/go...ntr-t73375.html
a few things to know:
it has recently had a new dump put on where it has a screamer for the wastegate, cant see how it would affect it.
the turbo is a stock R33 one on an RB20, using an RB20 actuator.
besides that i have nfi what ive done since the last time it was boosting up around 12-13psi as its been a while (was turned down a while back, also had to go through regency etc etc)
so yeh, any suggestions? is it possible for some components to fall out if the bolt isnt in screwed in?
https://www.sau.com.au/forums/topic/238331-cannot-boost-over-10psi/
you've lost the ball bearing that goes under the spring and bolt. The ball bearing is the valve. Without it, its just a direct connection to the actuator, hence 10psi because its a 10psi actuator.
Also, this particular MBC doesn't bleed.
Edited by KeyMaker
x 2
the ball bearing is so tiny you would never find it anyway.
im selling one in parts for sale section if ur interested
thanks mate, that's what i thought i was, going by a bloke in that thread it was around 7mm in diametre so ill try and grab a BB and see how it goes. is that all, any other components that could have come out?
a spring will be between the ball bearing and the screw, too strong tension and the boost will be too high, too soft tension and fully wound in the boost controller wont do a thing, too big a bearing it wont fit in the hole, too small and it wont close up the gap inside.
crap pic hopefully gets the rough idea
haha interesting, always thought it worked differently. so yeh guess the spring would have had to of come out for the BB to have. mm reckon ill take the thing out and go round to a few places and match the parts. cbf sourcing out a new controller as i need it by next sat.
thats only my understanding, maybe in more sane hours someone else can confirm thats basically how they work, i opened a mates up by accident once by unscrewing it too much and thats the order of things inside it.
the picture you drew is exactly how a manual spring and ballbearing type bleed valve works. Theres only one other type of manual bleed valve that i know of and its just like a "tap", same principle as a water tap. The sping type are much better as far as manual controllers go.
i would just go to any performance shop and just get a new turbosmart bleed valve, it cant be much more than 100bucks, if no good go to repco and they'll have something, someone will have one in stock. You'll spend all afternoon going around trying to get the right parts for the current bung one.
Just spend $30 and get a new Turbotech mbc. I wouldn't bother trying to source new parts as there was probably a fair bit of thought gone into springs specs and I guarantee you won't be able to get one the same as the one you lost.
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
