That BenQ sounds like quite reasonable grunt for the ask , will look into that one .
I think I'll get hold of the datalogit first and maybe kick the old P3 500 in the guts with XP and see what happens .
I really do want a more modern unit but if I can struggle on a bit longer with the old gear what is mid range now will be entry level in the not too distant future .
Thanks everyone for the hints and tips and should have an invoice from Stuart v soon .
Must be about time to skim through Paul33's FAQ , cheers A .
Edited by discopotato03
The centrino HP laptops they have been getting at work for the last few years still have a real serial port (ie RS232 with a DB9 connector). I dont know the model name but will try to find out tomorrow. Otherwise a PCMCIA aka PCCARD serial card may be better than a USB adapter judging by what others have said here, but personally i've not heard of many problems myself and we use them often to talk to switches/routers/unix/linux boxes.
That's an interesting find . I was talking to a friend last night who lives and breathes computer hareware and he said be very wary of anything withe Nvidia 8 series or later graphics gear , failure rates are a bit high and Nvidia is muzzeling the lap top manufactures to try and keep a lid on the bad PR .
So I guess it means Intel or ATI graphics goes on the wish list as well .
If you can find that HP model I'll check it out , cheers Adrian .
the issue with the nvidia gear is that they are suffering from the same issues the xbox 360 suffers from. if they get too hot too often the solder holding the chip to the board gives out, only an issue if the machine is getting really hot. the general fix for it has been to release updates so that the cooling fans on them kick in a little sooner.
I've datlogit tuned my '33 with my mac with xp boot and also run a tech edge 2E0 lambda no worries. Usb to serial not a problem although I've never been able to get the compare function to work. Probably was doing something wrong - haven't looked at it for ages.
Cheers
P.S Windows sux :(
ATM I'm loading (feels like loading a cement truck with a mug) a late XP onto the old P3 500 Toshiba because it's all I have with a serial port . My mate reckons 2000 Pro would be better on this dinosaur but have to wait and see .
From Whirlpool I found that Toshiba Tecra A8 143's have serial ports and so do HP NX 6320's - I think .
Looking around 2nd hand but I think waiting until the current crop of Centrinos (minus nvidia graphics) are cheaper is the go .
Cheers A .
http://h10010.www1.hp.com/wwpc/au/en/sm/WF...315-447371.html (NC6220)
Unfortunately its discontinued as well. The doco has the serial port labeled "vga" port, but you can see from the pin count its not.
P3 500 won't cut it , 4+ hours to load XP SP3 and 35 min to defrag the snail ?
Toshiba Tecra range lap tops seem to have serial ports and some of them are not desperate price wise for a reasonably up to date thing . I've been looking into A8's and A9's but yet to see one in the flesh .
Cheers A .
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
