Hi all,
Just wondering the best way to wire up a portable media player I have. It is basically a 2.5" enclosure with an AV output and requires 5V DC.
So is there a power rail or wire off the current deck that has 5V that I can run off or should I run a seperate wire, and if so how and where? :D
I will eventually make up some sort of bracket to mount this thing into but I'd like to get it going for now as quick as I can.
All your help would be greatly appreciated!!
https://www.sau.com.au/forums/topic/238357-installing-a-portable-media-player/
Hi all,
You will have to splice a power converter in, as I would imagine that there would not be any 5V power source there...
You might be able to use a Mobile Phone travel plug (12V to 5V) but it might take a while to find one the right amperage.
Why do you want to do this?
You might need some professional help to achieve a 'safe' result.
Chris Rogers sells an adapter plug that plugs into the TV unit that gives RCA plugs plus it also comes with a plug for the back of the stereo (v35 + M35 bose and non Bose 6 disc double din unit). The piece that plugs into the back of the head unit has a power supply. Not sure of the voltage, but i am sure Chris could answer this.
I use this plug to run my I pod through the AUX/2 of the TV unit and it also alows me to charge the Ipod.
Cheers
Andy
Actually I did buy that kit off you Chris, would that be sufficient to power this? the power adaptor that comes with the player says output +5V 2.6A. It's a Japanese power adaptor and therefor requires an AUS adaptor with it.
ok I cna make something for it. take a BIG photo of the adapter including any text that is on it. they usually give polarity of the plug. also have a ruler handy and give me the dimensions of the plug that goes into your player.
the harness I sent you will take a 10A feed easily.
Ok here we go:
plug is 4mm thick, just under 9mm long and diameter of hole is about 1.5mm.
let me know if you need anything else :P
Appreciated Chris!
Ok here we go:
Appreciated Chris!
that is doable. there are 3 versions of that plug so I'll include all 3. give me a bit as I have a bit on.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
