If I can have pictures proving that the rears are tens then I would be very interested.
Just can't see tens fitting that easily on the front.....
Edited by PbP-031
fronts 18x8 offset +35 pcd 114.3 tyres falken 225/40/zr18
backs 18x10 offset +42 pcd 114.3 tyres pirelli p zero rosso 255/40/zr 18 same tyres used on alot of ferrari's
these rims are rare cant believe no one has snatched them yet they came out on the veilside r33 gtrs
mate, ur a fkn moron that talks shit... if AND if they were gtr rims, they would be all equal sizes and offset...
more like 18x9+30's..
veilside gtr my ring hole... muppet
#1 - You guys shouldnt spam his thread to begin with. If you dont plan on being a serious buyer dont post.
#2 - Eiad, would be a good idea to not act in the way that you are because i can tell you that people will see how you act and would not want to buy anything from you
cheers
Eiad, want to say that again? Because my dad is more then happy to come and have a chat. If you want to f**k me around again he's happy to come see you :/
Again ? what u mean again never delt with u
PM replied to the idot. My offer still stands. I'll even pick them up. Well that is if their even at your house.
As nothing else was, wanker.
u got all your parts that u wanted wanker not my fault your transport company wont alow parts in the car
HA I rang them. You never even tried to take them in the car. Just like you told my dad that they were at your place and he rang you three times to check and they weren't
Dodgey guy, so don't bother buying shit from him. As I already got f**ked over.
go
the first tiem your dad came with no notice and the other 2 times i was busy wasnt around and u got all your parts and i chucked a set of enkie rims for free so go have a sook u lil girl
WTF you talking bout, the rims were in the sale thread already dickhead. I don't want them anyway. I still don't have everything you listed in the sale thread so, don't know what your going on about.
And the first time I rang you twice letting you know he was coming wensday at lunch time. So f**k up if you don't know what you going on about.
Further more, I WANT MY!!!!!;
3" HKS catalytic converter
Turbosmart boost controller.
Straight from your sale thread. And the "boost controller" you gave my dad is a f**king air hose fitting.
DO NOT BUY ANY THING FROM THIS GUY, YOU WILL GET f**kED OVER!!!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
