Guest Stocker
The other thing is to prepare your head. Go out here to have fun, but don't forget that you'll be driving really fast, so concentrate. Don't try and go flat out from the first lap, ease into it.
Keep an eye out for what the other people are doing. Be smooth(or drift if that's what you are there for!)
Regards, Andrew.
I can add another thing from my debacle today at Wakefield - either be 1000% sure that your brake pads will survive the day, or take a spare set. Pads for a skyline are surprisingly hard to find in Goulburn on the weekend...
Guest Impul 25T
Originally posted by red900ss
I disagree.
Tyres should be inflated 2-4 psi more than normal road pressure. The reason you are getting a "4-6 psi rate of expansion" is the tyre flexing excessively and heating up. This in turn heats the air which then expands and the pressure increases.
Running too low pressure reduces tyre life and increases the chance of damage to the tyre/wheels if you hit a ripple strip.
just my $0.02 :(
Are you talking street tyres or track tyres?
You do realise that a hot tyre is stickier than a cold tyre? You are trying to get that expansion, created by heat, to warm up the tread surface of the tyre. If you start to high, you won't get the right temperature increase in the tyres, and they won't get improved grip. An example, a mate's GTR on the track, running semi slicks, started out with a tyre pressure of close to 38psi cold, car skated around when the tyres warmed up. Dropped the pressure to 34 cold, next time out the car stuck like glue to the track once the tyres had warmed up. If you start at almost 40psi, when your tyres get heat into them and the pressure increases, does that not mean that you are more likely to run on the centre of your tyre..... causing undue wear?
Have any of you heard of drivers like Stuart Owers, Ray Williams? They say the same thing as I have just said, as has Sadistic Rage. I would tend to believe them, firstly, because they have been racing for over 15-20 years, and they are pretty good, ie, NZ champions in their respective classes on numerous occasions.
I am talking street tyres sorry if I didn't make that clear. Semi-slicks and race tyres are a different thing all together.
Street tyres DO NOT need to warm up like race tyres do. Different rubber compounds.
"You do realise that a hot tyre is stickier than a cold tyre?"
yep. Do you realise Street tyres warm quickly to their operating temperature and the temperature variation from "cold" to "hot" has much less effect on their level of grip when compared to a track tyre?
" You are trying to get that expansion, created by heat, to warm up the tread surface of the tyre. "
umm, sorry don't get what you mean by the expansion warming the tread?
I run my Dunlop FM901s at 37 psi front, 38 psi rear. I can tell you as that this is the correct pressure for my car etc. Many slicks typically run at around 22 psi.
I don't claim to know everything, far from it, but I know what I know. If in doubt talk to someone who sells tyres for track work (NOT your local tyre place :P ).
red900ss
Try 44psi front 45psi rear it might surprise you.... thats for the race track.... NOT the street or dragstrip.
37 and 38 would be typical pressures for an interstate trip or normal street if you tend to push things
Guest Impul 25T
I don't claim to know everything, far from it, but I know what I know. If in doubt talk to someone who sells tyres for track work (NOT your local tyre place :cool: ). [/b]
Sorry, when it was said for Track prep, I just assumed that slicks were involved.
The second part also refers to a slick, sorry, bad wording. The point I was trying to make is as the inside air tmp increases, it warms up the tread by convection.
I run my 901's at pretty much the same pressure also, and the last bit, definately ask someone who actually knows and has had experiance. Most local tyre shops pretend to know but don't really.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
