  • Replies 174
also sorry if my comments whwre a little gross, i did it in good humor, not to drill anyone.
but its the truth, i wont be able to watch, ill be there, but ill be looking from her side of the sheet, not the docs.
i cant watch RPA without feeling queezy, let alone see it in real life.
but hey, when its your own child being born, its a whole different ball game i spose.
soz amanda, didnt mean to offend.
well geez :) i guess what was posted was bad enough to get deleted?
and going by some1s post giving birth isn't meant to be clean and simple. every1 has a choice to watch a baby come out
it's spose to be an unforgettable experience HOWEVER i don't want any1 down that end of me unless there a doctor or midwife.
Craig- don't worry i did find humor in what you said, thank god i find KFC sickening lol
Dirtgarage (i think it was)- i am going to try and have an active labour and let gravity help, obviously i will lay down if my back pain
is just too much, or maybe sit in a bean bag if they have them.
nothing better than watching ya kids been born most amazing experince i saw both of mine and got too cut the cord :-) i reckon it all helps with the bonding with the child .
good luck with your birth amanda hope all goes safe and well
cheers dean
cheers dean
You cut the cord? :P I wear I would pass out trying lol...
GL with the pregnancy pokie :cheers:
Aleks
You cut the cord? ;) I wear I would pass out trying lol...
GL with the pregnancy pokie :)
Aleks
just like cutting a sausage with a sharp pair of sissors nothing to it harden up man for gods sake ya mrs will think ya a metro sexual lol
LOL i asked my dad if he would cut the cord and he won't, my mum told me he never cut
any of ours when we were born.
he thinks it will hurt hahaha. if he did cut the cord i'd scream just for the sake of seeing the reaction on his face ;)
Ever seen freddy got fingered?
Never, EVER will I cut the cord. lol.
he thinks it will hurt hahaha. if he did cut the cord i'd scream just for the sake of seeing the reaction on his face :)
That's cruel!
Aleks
it might be evil and cruel but it would be hilarious.... for me :D
i keep getting these damn contractions (there called Braxton Hicks, there practice contractions) and god they
are so painful, apparently there not meant to be but mine are lol, they keep waking me up damn it
it might be evil and cruel but it would be hilarious.... for me ;)
Hilarious, but you'll luse all your left over energy laughing and then pass out :P
Aleks
Aleks
ohwel it'll be well worth it hehe, beside i might be laughing anyway coz i'll have Gas :)
i finished the cot, after realising i don't need an instruction manual, i needed an Allan Key
so i went on a hunt into unknown territory (the shed) and started searching for 1, couldn't find
any then my brother got home and he got me 1 so WOO.
he thinks it's funny i know what an Allan Key is, apparently not many females do? ;)
anywayz here's the finished product :D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
