Originally posted by Sydneykid
Hi HJimx, if you can see a colouration difference in the spark plugs then there is alway more than 0.5 A/F ratio difference (oil usage not withstanding).  By moving an RB25DET from 11.5 to 1 to 12 to 1 A/F ratio you pick up 25 to 30 rwkw.  So if you have 1 cylinder at 12 to 1 and 5 at 11.5 to 1, then you are loosing 20 to 25 rwkw.  Remembering that  this is the minimum, a noticeable colouration difference could easily be 1.0 A/F ratio which is closer to 40 rwkw.
Now I have worked on over 20 X RB20/25's and have never seen one that shows any consistent spark plug colouration differences on 3 and 4.  I have seen it on differing cylinders but this is usually traced to lower flowing injectors or other factors.  It certainly is not airflow related with any consistency........
Well we agree on something:) I think the missunderstanding was that this post gave me the impression that you were saying that JimX's plenum was robbing him of between 20-40rwkw.
I dont understand how though ben ellis putting down 290rwkw with stock plenum (and head gasket;)) is relevant, as it has been demonstrated on many occasions that power well in excess of this is possible with the stock plenum. My point was directed at what I perceived to be a criticism of the efficiency of a front facing plenum when it obviously is no less efficient than the stocker.
  • Replies 87
Honestly if the power gain is minimal from a greddy plenum and people stiill want to buy them whats the problem
imo they look great and the time saved in changing spark plugs alone makes them worth it as you don't have that stupid cross over pipe in the road
Hi Steve, Ben has changed the head gasket, comp is down to 8.6 to 1. Truely I have seen 10+ GTST's with more than 260 rwkw that have standard inlet systems. I have seen one with 320 rwkw that had a totally standard inlet, so Ben's 290 is not outrageous.
There are more important things to be done first in the pursuit of power, when you have done those, then buy a plenum. But be careful with the airflow distribution.
Crikey Buster how often are you changing your plugs? I find the coils much more of a pain than the inlet pipe. With the 120 degree bend at the throttle body, I only have to remove one clamp, it takes less than 30 seconds, coils aaaaaahhhhhh.....
Were you live 300 rwkw is a breeze, we had the mobile Dynomax there a few weeks ago. The old RB20 made 245 rwkw, that's what minus 3 degrees ambient temperature will do for you. There is always more horsepower in a freezer....... only kidding.
I just bought a plenum from NZ for $450 second hand, their is only 5 of them in the world and they are a very cool looking design. There is no way I would of payed $600+ for it, $450 was about the most I would pay. This identical plenum is on an rb20 (the guy who made the plenums) and it makes over 400bhp @ 12psi (forged internals, etc).
What am I trying to say? I think they are worthwhile for throttle response and to make it easier for me to do my piping but I agree with Sydneykid that $1200 is too much for a plenum unless you have BIG power.
Also there is a guy on www.ozperformance.net forums called jdcustom who fabricated rb20/25 plenums that have tuned runners and retain all stock things for $550 and they look the goods. Maybe they are worth a look as people using similar plenums he makes on rb30et's are getting good power from them.
Babble over and out.
Evan
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
