Item: GTR sump & front diff
Age: ??
Condition: Good
Price: $300
To Fit: (What car) GTR, Stagea etc
Contact: not304(AT)optusnet.com.au
Comments:
In good condition.
Purchased for my Stagea but realised the ratio is different
https://www.sau.com.au/forums/topic/238439-gtr-sump-with-diff-etc/
  • 7 months later...
  • 3 weeks later...
Back up for sale due to being stuffed around for 2.5 weeks by MR GTR-32
I'm located at Blacktown NSW.
It's a R32 GTR sump, so whatever ratio they come out with (I forget now)
$150 come & take it otherwise I will scrap the POS...
Edited by inmate
hey mate if you still have the sump i might be interested to use it for a rwd rb26 convertion, only thing is i am near brisbane in queensland.
do you think it would be much to get it up here
michael
michael
Sure I could put it on a skid and send it up.
I will PM details...
  • 1 month later...
