Thanks Gav and that was mainly my doing , John just basked in the glory while I did the hard work:D :)
Top work from you and Michael and as I said , to be able to pull off the big circle/small circle consistently gets my respect..:)
I think the guys in Adelaide might be in for a surprise...
Cheers
Ken
yeah well not to sound ****y, but being confident is a start... and im confident we will do well in adelaide.
they probbly are in for a surprise.. as theyve never seen anyone else drift apart from themselves..
im really itching for some proper race track driving, and 3rd gear..
have only used 3rd gear a few times on the street (read: empty industrial area).
Gav
Just a thankyou again for all those that came and spectated/competed.
Was a good day and everyone behaved themselves ( well if you call drifting behaving:D :) ) and am negotiating for the next training day.
Will post a list of people after discussion with John who have qualified for the potential drift demo series next year
The rest will have to speak to me re. further practise.
As for the other thread , I deleted it as it got way too bitchy and we are all here for the common cause, promoting drifting in WA so lets put on a united front please ladies and gentlemen:)
If anyone whores this thread , it goes too:shake:
Cheers
Ken
Great day guys, congratulations to Ken!
You certainly proved your knowledge jumping into seemingly "undriftable" cars and getting them sideways.
Good luck to the guys heading over east, stick it to the JMS boys.
It was good to see low speed drift is all about car control and not big bucks.
The event gave a few new guys a (legal) chance to show off their skills, hopefully this will encourage more guys to attend a few track days and maybe step it up a notch.
I shot some footage, i'll try and get it captured and online soon. Advanced apology to anyone i didn't get on film.
Ken, next you'll have to get the Zig Zag turned into sealed road so we can have Jap style downhill battles !
On a serious note, keep plugging for "potential drift demo series next year", if you need a pile of signatures to prove there's public support let us know. I'm sure there's many on this list and others who could fill a page with signatures.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
