Would anyone be able to tell me if these body kits are a direct fit onto a 1999 Nissan Skyline R34 25GT Coupe? The reason I ask is, is because I'm looking at getting a body kit for my Skyline some time in the not too distant future, and I've heard people saying some body kits require additional work to make them fit and such. Cheers.
genuine bodykits are going to be the best fit.. but you are talking 7k + for a kit..
most fiberglass kits will require some modification to fit but depending on who you buy or how much you pay.. it all comes down to quality.. paying that little extra can make it so much nicer.. i got my front bar & qtr panels from DMD.. they required little modification at all
If you're worried about the parts not fitting, how about going to a shop which will be getting the parts in as well for you?
They won't really charge you more if the parts dont fit, you just pay a fixed amount for the parts and fitting/spraying
and that silver front bumper looks amazing :)
  • 1 month later...
ive got impul sides and rear :) I think they would go well together in my mind just visualising it. im not much of a fan of the impul front bumper.
i'll probably be going with a top secret or something style bar for my front if i ever change it as well
impul goes well with alot, its a nice simple style so it suits alot of diffferent bumpers imo, but id go for something more "boxy" and square like a top secret bumper, rather than something like the altia/aero kit
dori what body kit did you have? I remember seeing ur car in alot of pics while i was lookin for which body kit i wanted and it looked heaps good but i cant remember what it was ... just remember u had a nice one :)
*edit* - the silver one i think is a top secret bumper with a uras bonnet lip - worship.gif
and the blue one is just super sexy but i dont think its an actual car? not too sure
Edited by Jonno34
@Jonno - The blue one looks pretty fake.
At the current point in time I don't even know what kit I'd go for, let alone what car..
I'm still on my P plates (green phase (will be off next january though)..
I've only really been looking at skylines and/or the s-chassis cars (Silvias and such)
Reeaaaaaaaaaaaally considering an R34 GT-R conversion on my 25GT, with some 18' R34 GT-R Wheels. I just love the GT-R look, only way to go!
2 x R34 GT-R Front Guards
2 x R34 GT-R Rear Guards
2 x R34 GT-R Side Skirts
1 x R34 GT-R Front Bar
1 x R34 GT-R Rear Bar
1 x R34 GT-R Bonnet
1 x R34 GT-R Nose (the part between the front bar and the bonnet)
Got in contact with a guy who is in the process of getting me a quote for all the genuine parts. Still kind of researching the conversion. Buying the parts, getting the parts painted to match my current factory KV2, getting the parts fitted and having the rear guards welded on since they're not a perfect fit, and then buying a set of R34 GT-R Wheels in good nick... it all equates to $$$!
Will let you guys know if I'll even bother with it, depending on costs and such.
1 x R34 GT-R Bonnet
Got in contact with a guy who is in the process of getting me a quote for all the genuine parts. Still kind of researching the conversion. Buying the parts, getting the parts painted to match my current factory KV2, getting the parts fitted and having the rear guards welded on since they're not a perfect fit, and then buying a set of R34 GT-R Wheels in good nick... it all equates to $$!
Please, please, please don't.
Don't make it something it isn't, especially on a N/A R34 making less than 100kw.
1 x R34 GT-R Bonnet
I've got a genuine GTR bonnet and genuine East Bear bonnet lip for sale, click on my signature if you are interested :)
Guys i thought this was a thread for bodykit reference, not a discussion about kits you want/have etc...
On another note
I came across this thread, albeit a little old, might be a point of contact for anyone wanting a JGTC widebody kit
http://www.skylinesaustralia.com/forums/topic/56243-r34-wide-body-kit/
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
