  • 3 weeks later...
hey. just wondering if you can fit a nissan skyline gtr r34 body kit on a nissan skyline 25gt coupe.
im saving up for a nissan skyline 25gt coupe for my first car and this is what i want to do with it.
sorry about 2 of the same posts. the website got a bit confusing
yeap altia front bar, i think thats the east bear lip for the front bumper
the rear bumper is the nismo s - tune one
not entirely too sure about the side skirts though? perhaps thats the s tune skirts?
  • 2 months later...
This is the lip from viva garage, unfortunately mine was broken in transport :( oh well. I've fixed it up now. (note: it is not attached in this photo, it is just sitting on the boxes, so i could get an idea of the look.)
  • 2 months later...
  • 4 weeks later...
Hey guys im a bit of a noob when it comes to body kits so far...was just wondering if anyone could tell me what body kits will fit on my R34 gt 4 door skyline? Might be a stupid question but is the GTR fronts the same fittings as my origional one? its completely stock atm. Cheers
Go back through the 16 pages of this thread, you should find plenty of kits for your 4dr.
Hey guys. I'm new to this website so I'm hoping I have done this right.
I have just recently bought a 4 door r34 with a stock front bar and I'm looking to buy the factory front lip.
Can anyone please help me with where would be the best place to buy one from or where I should I be looking for one? I also live in SA.
I have some pics of what front lip I'm talking about.
  • 7 months later...
If i'm not wrong its about 8k or something to put an east bear kit on. I could be wrong though, its been a long time since i've looked into it.
imho, keep your gt/gtt looking the way it is, and if you want a body kit, get something that was made for gt/gtt, keep the authenticity of it. It'll also be alot cheaper. think about 2k for sides/rear including fitting/painting?
when i first got mine i just wanted it to look like a gt-r. but after i'm so glad i didn't. mine just has a basic impul sides/rear on it, and its been lowered onto some 18" wheels. you could do something like the altia kit, very popular, so if you sell it should be all good :)
it'll make the gt-r that much sweeter when we finally get it ;)
    • I'd say the easiest way is, pick up a extended and baffled sump with fittings already welded on. Here is an example, it has 3 x -10 fittings  https://shop.maatouksracing.com.au/products/rb-extended-and-baffled-sump
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
