hi i own an r32 and am about to purchase some wide front and rear guards for it
now ive heard dmax is of the best quality, anyone bought dmax or know of the quality??
i should hope so that they good quality for $400 a pair front and rear
now the dmax branded wide guards only come in i think 15mm or 20mm rear fenders and 15mm front (although there is the d1 spec 30mm front guards but they stick out outside the door)
so i dont know if should go with the dmax fenders?? or go for cheaper more wider fenders from somewhere else?
anyone know where i can get some wider ones that are of good qaulity?
sorry for all the questions
thanks guys
https://www.sau.com.au/forums/topic/238496-front-and-rear-wide-guards/
yeahh i bought the dmax front fenders and just fitted it like 3 weeks ago
all i can say is that i encounter a few problems ..
first of all the fenders are too thin which can easily be crack if someone lean on it
so i had it re-fibreglass which cost me $100 each ... (rip off i reckon)
and secondly the tip of the fenders where it line up with the front corner indicator
has a gap that run all the way down ..hard to explain need to show you guys pics
and lastly it dosent line up with the bonnet properly, it sit abit higher ..
thats about it ..maybe it was just a one off thing for me or the guys
that installed it did a shit job .. wasnt happy they offered to fix it but
i have to leave the car there for a few days .. havent had time .. soo blahhhhhh
other then the above problems it fits good and look good aswell
  • 4 weeks later...
dude imho spend the money and get decent guards i payed 500 a pair front and another 500 for the rear they were espensive but the quality was awesome.if you go cheap guards almost always the quality will be shyte, they were veilside combat r by the way on a r33
dave, the part where it sits higher then the bonnet, that can be fixed with just some sanding to make it even :down:
if you got problem with them, speak to the dmax seller/rep and he will look after you.
URAS gaurantee 100% fitment on them, but it also depends on the car whether its had previous accidents etc.
heres a picture of mine. for some reason the front guards are strange.. the bottom of the guard where the side skirt meets it is narrower than the factory one and leaves quite a big gap
behind the wheel. dont know if they were made that way intentionally??
thats one fkd up widebody job it looks hell dodgey + those wheels dont fit what so ever ahahha fail
geez a bit harsh considering i spend 2 hours a week working on it for 4 months not to mention im not an exprienced panel beater :)
lineedup33 i got them imported from japan
do you have any more pictures of this?
think it looks wierd cause of the rims, rims look abit to small and needs some (alot of) dish
but good work for a non exprienced panel beater :blink:
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
