Hello,
I have a 1992 nissan skyline gtr with 18x8.5" on the front and 18x9.5" on the rear with unknown offsets and unknown spacers so I am running just rwd for now but I would like to run awd and I would like to get rid of the spacers because they are not hub centric so the car shakes at around 100km/hr. Hence, I would like to run 18" rims but I need help choosing an offset and rim width. I have found that I need a rim with a centerbore of 66mm but I cannot find a common response to the offset and rim width.
Thanks,
Justin
if you are looking at 18inch then 18X9 with offset between +30 and +18 will be suitable. or 18X9.5 with offset between +30 and +22 is good too. tyre size either 245 or 255 will be fine too. then you can chuck out your current mismatched wheels and frisbee the spacers over your back fence!
the PCD is 5 X 114.3.
a popular choice is R34 GTR wheels which come in 18X9 +30 and look great on a 32. they fit perfectly, are forged (so light and strong) and can be had for reasonable money.
so you get these (my 34):
and put them onto this (my old 32)
Hello,
I have found some bronze Nismo wheels for the 2003-2008 350Z fronts. They are 18x8.5's with a 25 offset. I found them for $800 and apparently they are new. Do you think they would work and look good?
Thanks,
Justin
they will fit "okay" but in my opinion not quite the right size or offset for a 32 GTR they will look too narrow for such a tall wheel. ideally you want a nice 18X9 +20. that will be perfect. also it makes it far easier with the 4WD if you stick to the same size and offset all round and use the same tyre size all round. also means you can rotate tyres front to back to get more life out of them. :rofl:
I have 18x9.5 +20 wheels on my R32 gtr and the wheels/tryes sit about 5-10mm inside the gaurd. perfect for what I want, no scrubbing etc.
Ryan
What size tyres do you run on those wheels??
I am considering 17x9.5s or 17x9s for my R32 GT-R, trying to research whether the 9.5s will fit ok (the wheel I am looking at is a +17 offset in the 17x9.5 size - Work Emotion XD9)
yep - 9.5" wide fit no problems. I run 18"x9.5" with a +13 offset and they are probably right at the limit.. and that's running 265/35's.. but a +17 will be 4mm further in, so should look good and give you that little bit extra guard clearance.
Hello,
Thanks you have been alot of help, I found a set of r34 gtr rims but the previous owner says that he is using spacers? Why would he do this?
they dont quiet fill the guards, i ran about an 8mm spacer when i had 34 wheels on my 32 gtr they would sit just inside the guard.
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
