  • Replies 66
Posted Images
nah didn fix it.. i already posted that lol! sigh but yeh least shes got new sparkies..
Its a process of elimination then! Knock off the list what it could be, until you find what it is! :banana:
Its a process of elimination then! Knock off the list what it could be, until you find what it is! :D
aw that sucks, even though i may be replacing parts, i could be doing somthign wrong.. so i guess ill start fromt he beggining..
afm - checked it out.. i have an aftermarket z32 (which could be causing the problem)
sparkies - i changed over though i didnt use a tensioner bar.
coilpacks - my car is not babying on 2.5k or missfiring so im pretty sure i can rule that out
bov - i changed over to my stock one, but now it plumsback through my pod which could be causing a problem
other possible things people have said is the ecu?
if theres anything ive missed feel free to add.
yeh ive been really busy lately, not to mention i dont wanna drive around just incase i get caught.. but i will eventually get round to it, perhaps on the week end ill see how it goes.
hey i noticed today that when i was ideling and used something electrical my revs dropped a tiny bit.. eg if i used the electric windows or wipers etc
also it does the same thing when i lighty push on to the accelerator, so when i take off at the lights it almost stalls then the revs pick up.. and i sort of nose dive :)
i think this only happens after ive been driving for awhile.. when i first take the car for a drive, shes all good.
maybe im in need of a new battery? or alternator?
the slight dropping of revs with lights etc is normal if it isn't any more than 150rpm. It's just your alternator placing load on the motor...The vct solinoid can create a slight drop in revs when you touch the accelerator but shouldn't ever have an effect on your driving.
No it dosent effect my driving because i have my foot on the accelerator, but at the lights when im leveling first gear, the moment i put pressure on the accelerator the revs drop dramatically and almosts dies so i quickly just give it more gas, YES i can drive manual, say when im in neutral and i just step on the gas ever so lightly the revs will splutter and drop till it dies.. so i have to double tap the accelerator so when the revs drop i can quickly catch it.. sorry for the bad description, iono how to put it anyway else ;)
i have a similar problem with my car, it idles under 1000, and occasionally when im waiting at say, the lights or a roundabout waiting for other cars to go past it stalls even with the clutch right in. it's due for a service and tune anyway, so i'm just booking it in at boostworx
i can come to you and we can swap things on my car and see what the problem is like afm i also have a spare ECU we could try as well
by the way i dont drink lol
OMG KELLIE UR THE BEST!!!
lol sorry everyone kellie has WON the free beer slab :) plus money for the new ECU..
SO far, so good.. ill get back to you asap kellie, probarly next week on the wednesday because its my day off.. IF thats ok with you, if anything just call or text me on the mobile.
Well looks like it was ECU problems, kellie told me that perhaps when they installed my deck unit, they could have short circuted my ecu, so yeh we swapped mine over for her spare R33 series 2 ECU, yeh started and everything, took her for a spin and yeh much better response hasnt died on me yet.. but im abit iffy that the series 2 might not be compatible.. working fine so far & no engine lights on.. im gonna surf the net and see if there are any major differences, but yeh so far shes running like a dream.. just hoping that the problem is fixed now, stress free :nuke:
ONCE AGAIN thanks kellie ur a legend!
ill keep the thread open just incase somthing screws up, but yeh thanks to everyone who contributed whether it was big or small..
SAU ROCKS MY JOCKS!
nada ;)
ARGHH, shes still dieing randomly :P and also now when i drive over a bumpy service shell like shutter, its weird as... i think i need a series 1 ecu.
But yeh im pretty sure its the ecu, because when we put in the series 2 she seemed to be better, and died less times :)
either that or its a different problem..
http://www.skylinesaustralia.com/forums/R3...1-2-t17349.html
i came across this post, and yeh seems like theres quite abit of differences between the series 1 and 2 hence the ecu not performing good.
The series 2 has an ignitor built in the ecu, as for the series one has it seperately, so that could explain the weird shake/shutter. ill try source out a working series 1 ecu and see how it goes, when i have some free time.
yea as far as i know the series 1 is like the r32 and changes after
do you mean same as in the car specs or ecu? so if i got hold of a r32 ecu i can just plug and play?
and would it matter if it came off a manual or auto?
i cant seem to find any stock ecu's :/
ill have 1 u can borrow soon mate to test, aslong as your car is manaul
is it still running the same?
or does it run like a dog, i wold be checking either ur sparkplugs, coil packs (cause when u play with them in rbs they f**k up), or go and get a compression test done. hope this helps
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
