ok many a time when i put a little extra presure on my velocitator, say all the way in... and im flicking into the next gear, it catches and grinds the gears when trying to get into the next gear, YES i have the clutch all the way in and im not doing anything wrong, but im just thinking has the previous owner beat this tranny to shit? this happens rarely but makes me poo when it does.
someone tell me something!
https://www.sau.com.au/forums/topic/238582-is-it-time-for-a-new-transmission/
ok guys update, i drained the oil and got some good motul oil, 40 bucks a bottle, hope it does the trick, thing is i used 3 bottles, and it didnt start tipping out of the fill up hole, how many litres are supposed to be used to fill up the gearbox?
2.5L. Smurfs blood is the best thing you can put in there. What exactly was this Motul stuff you put in?
A gearbox with 2-3 new synchros will cost about $1500 to rebuild which is what is required if the best oils don't help. That doesn't include remove and refit.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
