I am selling my spare engine and gearbox. I have most 2 door R33 parts available but no front panels
R33 GTS-t gearbox in good condition $1350 or Manual Conversion Kit for $1600
Series 1 RB25DET Motor, No Turbo, Injectors, or Fan Otherwise Complete $1350
Loom, AFM, Computer Extra $250
I am also putting my r33 back to standard as I am selling the car so most of the aftermarket parts are for sale. Most of these parts are in the car and can be test driven at the moment
Nismo 550cc injectors $400
HKS 2535 340hp Turbo with Twin Dump Pipe $1500
Z32 AFM and Plug with Apexi Pod $250
PowerFC and Hand Controller Tuned for 250kw with the above Mods $1500
I will sell the lot for $3200
You will need Exhaust +Front Mount + Boost up to get over 300hp
I have done high 12 secs in my R33 4 Door with this setup. Can be test driven
Splitfire Coils done less the 400km $450
Nismo 2 Way LSD in Housing for R33 $1000
Tein Super Street Coilovers R33 GTS-t $1000
R33 GTS-t Manual MinesComputer. No speed limit, Revs Lifted, Suit Boost up and minor mods $350
I can also sell the motor complete for $5000
1994 RB25DET Series 1 - Good Reliable Strong Engine
Blitz Blow Off Valve (Unknown Age)
New 6Puk Copper Mix Clutch, Machined Flywheel, Heavy Duty Pressure Plate Rated 440hp (200km)
Gates Racing Timing Belt (2000km)
Tomei Adjustable Cam Gear (2000km)
Splitfire Coils (400km)
Nismo 550cc injectors (16000)
HKS 2535 340hp Turbo with Twin Dump Pipe (16000km)
Z32 AFM and Plug with Apexi Pod (16000km)
PowerFC and Hand Controller Tuned for 250kw with the above Mods (Tuned 16000km Ago)
Had new plugs 2000km ago and new oil, and filter 200km ago
are you will to post and could you put up some pics
Injectors Sold Thanks. I can post
Edited by Brokenz
UPDATES - This new system where we cant edit posts is shite!
R33 GTS-t gearbox in good condition $1350 SOLD
Manual Conversion Parts $200 (Drive shaft, Pedals, Master Cylinder, Manual shifter Surround, No Slave Cylinder)
Series 1 RB25DET Motor with Loom, 107000km No Turbo, Alternator, or Fan Otherwise Complete $1350
Nismo 550cc injectors $SOLD
HKS 2535 340hp Turbo with Twin Dump Pipe an Lines $1500
PowerFC and Hand Controller Tuned for 240+kw with the above Mods + big exhaust, pod filter, front mount $1500
Splitfire Coils done less the 400km $SOLD
Nismo 2 Way LSD in Housing for R33 $850
Tein HA Damper and Height Adjustable Coilovers R33 GTS-t $850
Edited by Brokenz
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
