I am selling my spare engine and gearbox. I have most 2 door R33 parts available but no front panels
R33 GTS-t gearbox in good condition $1350 or Manual Conversion Kit for $1600
Series 1 RB25DET Motor, No Turbo, Injectors, or Fan Otherwise Complete $1350
Loom, AFM, Computer Extra $250
I am also putting my r33 back to standard as I am selling the car so most of the aftermarket parts are for sale. Most of these parts are in the car and can be test driven at the moment
Nismo 550cc injectors $400
HKS 2535 340hp Turbo with Twin Dump Pipe $1500
Z32 AFM and Plug with Apexi Pod $250
PowerFC and Hand Controller Tuned for 250kw with the above Mods $1500
I will sell the lot for $3200
You will need Exhaust +Front Mount + Boost up to get over 300hp
I have done high 12 secs in my R33 4 Door with this setup. Can be test driven
Splitfire Coils done less the 400km $450
Nismo 2 Way LSD in Housing for R33 $1000
Tein Super Street Coilovers R33 GTS-t $1000
R33 GTS-t Manual MinesComputer. No speed limit, Revs Lifted, Suit Boost up and minor mods $350
I can also sell the motor complete for $5000
1994 RB25DET Series 1 - Good Reliable Strong Engine
Blitz Blow Off Valve (Unknown Age)
New 6Puk Copper Mix Clutch, Machined Flywheel, Heavy Duty Pressure Plate Rated 440hp (200km)
Gates Racing Timing Belt (2000km)
Tomei Adjustable Cam Gear (2000km)
Splitfire Coils (400km)
Nismo 550cc injectors (16000)
HKS 2535 340hp Turbo with Twin Dump Pipe (16000km)
Z32 AFM and Plug with Apexi Pod (16000km)
PowerFC and Hand Controller Tuned for 250kw with the above Mods (Tuned 16000km Ago)
Had new plugs 2000km ago and new oil, and filter 200km ago
are you will to post and could you put up some pics
Injectors Sold Thanks. I can post
Edited by Brokenz
UPDATES - This new system where we cant edit posts is shite!
R33 GTS-t gearbox in good condition $1350 SOLD
Manual Conversion Parts $200 (Drive shaft, Pedals, Master Cylinder, Manual shifter Surround, No Slave Cylinder)
Series 1 RB25DET Motor with Loom, 107000km No Turbo, Alternator, or Fan Otherwise Complete $1350
Nismo 550cc injectors $SOLD
HKS 2535 340hp Turbo with Twin Dump Pipe an Lines $1500
PowerFC and Hand Controller Tuned for 240+kw with the above Mods + big exhaust, pod filter, front mount $1500
Splitfire Coils done less the 400km $SOLD
Nismo 2 Way LSD in Housing for R33 $850
Tein HA Damper and Height Adjustable Coilovers R33 GTS-t $850
Edited by Brokenz
