Hello to all you skyliners out there - ok guys i am i suppose you could call it going into my mid life crisis i have always wanted a r33 skyline i do have a 2004 BA XT FALCON (dont mean to offend anyone here because its a ford) i also have a company car to drive so i am looking at getting rid of my falcon and getting a skyline for my sundays i am looking to swap my car with one plus $1000 dollars cash must be r33 ,manual,not fused on color with a couple of mods or would consider a decent r32 i am looking around the $11000.00 for my car plus the $1000.00 so if there is anyone out there at maybe a swap or a second car please let me know i am from Melbourne thanks guys
https://www.sau.com.au/forums/topic/238613-looking-for-an-r33/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
