I'll no longer be at the west pre-meet, but anyone else coming from the west is obviously free to still meet with any others at the meet point and head down together...Shattered that I'm gonna miss this, hopefully I'll be at the next one!
Have some duck for me mah man!
  • Replies 130
Dammit I have to be on EXTRA good behavior, do we have to have it on Monash ground? I don't think it will go down to well with the rest of the student union if trouble does start hahahha jk
See you all there, I'll be boasting the regular cruise channel on my UHF on the way there from Caulfield campus if any of you see a silver 33 with xxx234
Will probs hit up a near by repeater as well in case ppl get lost
Decided to mock this up to get a feel of the crowd...went on posts please tell me if this is wrong really hope everyone shows! Going to be a great night!
Expecting at least 15+ cars!
Confirmed (Or Close to it)
RCHOO (Wayne) - R33 GTST
(00)SKYLINE(00) - Bringing his R34 GTR Nismo S1 (NO IFS OR BUTS...PLEASE!?)
BASTI (Niroj) - R33
R31NISMOD (Ash) - R31 GTS-R
FEMNO (Mat) - R33 GTR
GTS-T SEDAN (Nick) - R32 GTS-T Sedan
ADAM (Adam) - R32 GTS-4
JamesK (James) - R33 GTS-T S1.5 & Guest(s)
DNGRUS (Ferah) - R34 GTT
KIRAS (Guess) - Audi A4 B6 & Guest(s) (Team Ignite)
Wheezy - R31
DOGKNIGHT (DK) - R33 GTS-T S2
CHEEZ (Daniel) - R34 GT-T
AP - ?
If/But/Maybe/..../Intrested/Work/Excuse/Bla Bla Bla/Whatever (PLEASE COME!)
R33GOD - R33 GTR Vspec
LLAMA_AU (Juliette) - N15 or R34 or both...hopefully
KRZYSIU (Kris) - R33 GTS-T S2
LIL_LUCKY (Chad) - R32 GTS-T
HTIAL (Laith) - R33 GTS-T
B3ZA (Bez) - R34 4
RICHAR (Richard) - R33 GTS
AL (AL) - R33 GTS-T
ADAM -__- (Adam) - KE70
SHOTGUN!
Jeaneen - KIRAS'S Wingman...
Nick - KIRAS'S Wingman....
Vish or Sarah or Both - JAMESK'S Wingman....men...wo
...NEEDS DRIVER!
DEZZ (Michael) - Wingman
Cant......(WHY?)
MP_R33 (Ross) - R33 GTS-T MP - ....Comeon!!!
eMsta (Matt) - Jazz - You've used that excuse already!
LEANBAC (Allen Paul) - R32 4 - .....Comeon!!!
Edit: THANKS BASTI!
BASTI (Niroj) - R33
FEMNO (Mat) - ?
Wheezy - R31
HTIAL - R33 GTR
B3ZA (Bez) - R34 4
AL (AL) - R33 GTS-T
SHOTGUN!
AP - KRZYSIU'S Wingman...
...NEEDS DRIVER!
Cant......(WHY?)
a few things. kris is riding with ap (which means ap is coming), nick might be riding with kiras, laith (htial) has a gtst and femno has a gtr. well done other wise :)
When you say nick do you mean R33 sedan nick? And whats AP driven?? Thanks for the corrections
Shh... ...believe it's a GT-R and it will be...
Cant......(WHY?)[/b]
My Jazz is top secret - i only bring my R33 gtst to these meets
a few things. kris is riding with ap (which means ap is coming), nick might be riding with kiras, laith (htial) has a gtst and femno has a gtr. well done other wise :P
GTST Sedan is Nick. AP drives a 32 4 door GTSt too.
i have a car its got 4 wheels
however its sitting in the garage and ill be rocking up in a telstar :P
:P Bring it anyway !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :P
:cool: LOL!
Actually its my friend Han, his car. You know the one off the Just Cars Add... And you probley saw it at the Auto Salon.
BASTI (Niroj) - R33
Wheezy - R31
AP - ?
B3ZA (Bez) - R34 4
AL (AL) - R33 GTS-T
SHOTGUN!
...NEEDS DRIVER!
Cant......(WHY?)
Edit: THANKS BASTI!
LOL!
Good write up there JamesK. Makes things a lot more interesting.
Will see about the S-Tune, if not a R32 GTR or a V-Spec R34 GTR.
Cool!
haha, R34 only. I may rock up to an SAU meet in the Pulsar one day for shits and giggles.
I will be there! To wash or not to wash the car?
Edited by llama_au
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
