I was just wandering how does a r33 get flames out the exhaust?????
Is it just something that happens when a shit load of extra power is thrown to it? Is it a fuel additive?
https://www.sau.com.au/forums/topic/238615-flames-out-of-a-gts-t-exhaust/
Natural way: Car running rich and when the exhaust is hot the unburnt fuel ignites and causes a bit of a flame (usually from a car running no cat).
Non-natural: Run a flame thrower kit with a spark plug in the back of the exhaust which can be activated to cause the flame, what you mainly see in movies.
Car's running anti lag or BeeR revlimiter's also pop decent flames.
A mate driving behind me noticed that I had flames coming from my exhaust when booting it hard.
Took the car to Protek and Dom said it was just a tuning issue. After having the car tuned all was good again and haven't noticed the problem since.
would it do it at all with a high flow cat???? also i will degut it but later on in time, i just put the thing in lol.....
now i'm thinking how to degut the cat???? Its a 3 inch xforce from just jap, i think its still ceramic with flow near 600 ish???? is it easy to smash with a chissel or would i need something else???
Just for the record, doing that is illegal and can hold a huge fine if you're found to be driving without a cat converter.
Are you trying to stop the flames happening, or are you trying to get flames out of your exhaust? :(
When I got my new zorst my tuner was adamant that it had to have a legit high flow cat due to his exposure if the EPA caught up with me. So, I'll presume based on his reputation and his self confessed, self preserving ways, that is what I got. The other half of this story is my car blows big flames. I've caught them in my side mirrors in full day light and at a recent track day I was told it was blowing flames 'big time'. The back of the car needed a cut after the track day which I'll put down to flames or a toxic over rich mixture, or both......
It runs super rich when you give it the full pedal, so I guess plenty to burn with a hot pipe.
That's my experience.....
you cant shoot flames with a cat
Wait for me to get my car back on the road, and I'll prove you wrong on that.
I used to shoot 1 foot long bright blue flames out the back of mine sitting at the tree waiting to launch. WITHOUT Anti Lag.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
