Boost automotive or duggan and parker. they are the same thing.
on invermay rd.
please dont ask how good they are or you will start a massive bitch fight like usual.
i personally would go there. ive been happy with my service.
https://www.sau.com.au/forums/topic/238653-dyno-launceston/#findComment-4171775
Hi man
I also believe you should save your self and car and go to hobart.
HAHAHA is that right..
I have an R33 - Microtech LT12s and I am in Hobart... looking at around 400RWKW and my car is going to Brad Sheriff @ Boost Automotive.
EDITED: Slander removed from post
GMB
Edited by grandmasterb
https://www.sau.com.au/forums/topic/238653-dyno-launceston/#findComment-4176709
Keep it on topic and keep the personal crap off the forums guys, there is no reason to run down someone's name/business name and if it continues then warnings will be given!!!!
If you feel you have to express yourself then please keep it to PM.
Mitch at the end of the day its your car cobber and you are the one that has to be happy with the final result and the process along the way. Ring around a few places and have a chat (if they have time) about your car's set up and the advice that they can offer and go from there. Don't just rule out coming to Hobart because its too far, a tuner here "maybe" able to get better results with your car than others around the state and vice versa.
Also posting up the specs of the car would help people offer "opinions" on who to seek for tuning as well and if there tuner is able to look after the ECU of choice
Good luck with it :)
Ben
https://www.sau.com.au/forums/topic/238653-dyno-launceston/#findComment-4176850
Brad does a good job. You just need to tell him all the stuff that's been done to your car, and what you want/don't want done with it and you won't have any problems.
Hi man
and how that's not slander i'll never know.
https://www.sau.com.au/forums/topic/238653-dyno-launceston/#findComment-4177449
brad got 263 rwkw out of me old rx7 in under a hour ..with out knowing a thing about the car and the damm thhing would not even start when i got there...
once the turbo engine back in the commy im there no hesitation .....i also found that he talks in you lingo not jargen that ya can understand ,and all you have to do if you dont understand something just ask he will take the time to explain...
https://www.sau.com.au/forums/topic/238653-dyno-launceston/#findComment-4192597
Thanks for all your help guys
sorry never replied been stuck down at work doing a lot of overtime only got back yesterday
i heard brad was pretty good few of my mates have taken there cars there and are happy with the result
My car doesnt have and big mods just the usual
HPI Intercooler
HKS Pod Filter
Turbosmart BOV
3" Exhaust System
nothing much but thought i could maybe get a tune as i am getting major body work done at the moment
400R Front Bar, Rear Bar, Skirts, Bonnet
+50 Front Vented Guards
Custom Rear Guards
19x11 rims in the back and 19x9 at the front
and a drift wing when i find one i like
https://www.sau.com.au/forums/topic/238653-dyno-launceston/#findComment-4219750
I agree that it doesnt really need a tune with those mods, however like ben said its your car.... If you are from Burnie, How about going to
white hot motorsport?? i think that they should still be about. they are at 8 Mathews way Devonport. If you want a number to them i got it somewhere just give me a PM.
They would be closer for you
Cheers --Ben
https://www.sau.com.au/forums/topic/238653-dyno-launceston/#findComment-4236379
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
