Cam Gears
SiR_RB
 Share
hey guys
im getting afew bits n pieces together so when i get my safc and go to get it tuned, they can install an exhuast cam gear for me while im there,,
anywhos ive been lookin on ebay and you can pick up just an exhaust cam gear (rb25) for like $75
has anyone used one? they state that its made from billet aluminium with most having metal teeth to prevent wear.
how good are they? last thing i want is for the teeth to wear, or cause timing issues. how accurate are the markings? eg. 2degrees = 1 mark ?
any info would be great
A mate has brought the spool ones off ebay and has been running them for the past couple years. I have just ordered some. They are pretty good. The only thing i would recommend would be to do what my tuner does and replace the screws that you tighten into place when the desired timing is found thus stoipping them slipping in anyway.
People always say shit like the post above but they never say why. There can be some good buys off ebay as long as the proper precuations are taken. Although if your that worries you can buy tomie and greddy off ebay so it cant be all bad.
Good luck and keep us posted.
GKTECH gears look to be good quality
That's what I was planning to use next week for my GTR, what screws do you need to change to and where are they available from?
Thanks
IMO, anything timing related, don't skimp. Just go get a decent set of tomei or hks gears for like an extra $100 dollars and know that you'll never have issues. I got a Tomei gear in mine but I paid $200, im SURE you can get it cheaper elsewhere.
Thanks
Just take the original bolts that come with the cam gears, go to any bolt shop and match them up and grab them. Not much involved at all. Aparantly the bolts that GKTECH provide you with are of very poor quality which tend to break. Bolts that you would buy from any hardware shop like Bunnings or an actual bolt shop will be fine. They've been good in mine!
i was abit worried about the quality of fittings and the teeth/geers wearing.
if i do decide to grab one from GKtech im make sure i change the bolts - chuck on up stainless steel ones :)
hows the JJR cam gears? they looks good and r only $149, anyone used these?
WARNING ____ Anything that is a part of that timing belt setup can foobar your engine if it causes failure of that system.
For sweet FA you can get a quality product. Trying to save $100 on cam gears if so stupid when you think about how much fuel you use in a month.
Having to modify something because it comes out of the packet shite?
I have always used decent equipment, and I would have to say that I have a tool fetish, so don't think that I don't totally understand.
Looking at the differences between the varied cam gear sets I can only see the differences being the fasteners, the colour and shape and the material used..
Fasteners aren't a problem as lots of brand name equipment I have had to modify out of the box to make it serviceable to my standards.
Colour and shape, who gives a toss, as long as clearance is ok and the design isn't weak but from what I have seen that shouldn't be a problam as they all seem to be copies of tried units.
This just leaves the material. HKS cam gears of old are known to wear badly, with a change in the gear metal this has supposedly been fixed.
What type of material was this?
What do other manufacturers use?
All the ebay ones seem to use aluminium alloy either T-6061 or AL7075-T6.. Is this an inherent design flaw?
It looks like cams and cam gears will be on my list sooner rather than later, so I would like some information to make an informed decision, rather than having to base my decision on whose has the bigger price tag for the name rights.
James.
Not sure that I'd be using bolts from any hardware store, especially bolts that are under tension/strain. Bolts are rated by tensile strength and range from soft alloy crap to stainless steel and high tensile steel. Take your old ones to a proper bolt shop like "Universal Fasteners" and the bloke behind the counter should be able to take one look at them and tell you exactly what tensile they are.
James.
Hi James,
Looking at the gears they may appear ok but, If you have ever machined something for yourself on a lathe you will know that you can get it spot on or miss the mark. Part of it is how skilled the operator is and part of it is how good the equipment is. I've made a few pulleys before and a balanced one of even measurement requires a tiny bit of care. Care you find little of out of the factory these come from.
I mean if they gave a damn, why are you getting bolts that are unsuitable? Maybe they don't know what they are doing?
I've chucked a few of those cheap gears away for people, after showing them the gears are of a poor measured quality. The faults that I have seen include (but, I'm sure aren't limited to);
* Crap bolts (we have a fix for)
* Incorrect thickness
* Un-even thickness
* Incorrect tooth pitch and hieght for belt
* Incorrect markings
I picked up the issues both before installing and another due to a friend having some noise on operation, unlike stock gear (due to above issues) a guarenteed issue down the track.
It also machined off some material from the Cas/mounting. Great having little metal filings on your timing belt. If anyone has had that on one of these gears and still has it on thier motor my advice is to throw it away quick smart.
So take out some measuring tools and check these things if you must be cheap ass about it. Your eyes aren't good enough and like I said this little cog can root up your engine if it causes failure. Cheap insurance = quality control.
For the extra $100 I'll let some band name factory do my quality control. I can't be stuffed for the time it takes to check properly. So here HKS have my $100 :merli:
The old HKS gear issues are not proven by the way. I have had a couple and they don't have a problem. I consider it an old wives tale.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
